pump voltage map is tuned badly
Hello, the car is Seat Leon 1.9 TDI 110 h.p. 2003 year with EDC15 computer. The car is remapped, my question is why the real fuel consumption is 6-7 L/100 but the car computer shows on the cluster 2.5-3.5 L/100. Its much difference between the real and calculated numbers. I've tried to fix it with VAG com in instruments panel settings but there i can choose between -15 (-) +15% correction. There is much more difference, so is there an option to touch some of the ECU maps to fix that problem (I got MPPS device)?
bFlash/Kess/Ktag/CMD Master
DPF/EGR/DTC/AdBlue/ChipTuning. ------>PM
fzhut (1st February, 2018)
Duration map too much advanced.
Ok, so what should i do ?
Buy good tuned file
Wysłane z iPhone za pomocą Tapatalk
DSG TUNING
File Service
Post the file and let us check it.
Verstuurd vanaf mijn SM-A520F met Tapatalk
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
