File is no good, read again as 16 bit
Hi Guys,
Friend ask me to do the Dashboard Motobike, i cant find the Mileage.
Picture from Dash, but not Original Picture (found Pic in eBay)
Found EEPROM 93C56, open only Backcover
Original Mileage: 41.0XX
Need Mileage: 15.000
suzuki r600 ORI.rar
Please Help
Sorry
Read again in 16Bit
suzuki r600 16BIT ORI.rar
Original 41054
bersch8688 (3rd February, 2018)
Big Thanks
and write Back File 16BIT?
yes .............................
Good evening. I am asking for help in changing kilometers
old 49716km.
new 34716km.
here is your file
new.zip
marcinxxx22 (4th October, 2018)
Thank You...
Hi All, My friend has this same GSR600 dash unit. He has 7100 actual miles on the bike but was involved in an accident and the replacement cluster reads 14416 miles. We've had a look at the PCB and can see the EEPROM is a chip with the model S93C56 BD (Same chip as above I believe). What sort of programmer will we need to read and write from this IC? We found a few data sheets and they suggest the pins are CS SK DI and DO. Guessing this is SPI? What programmers do you all use for IC's like this?
Thank you!
Take the c56 off the board,and any programmer should be able to read this eeprom
Thank you Johnner!
I'll give that a go!
Sorry about all of the questions... But do you know anything about using an Arduino board or an FTDI USB as a programmer - equally I've found a programmer with a CH341A chip, do you know if this will work?
Thank You jomberykaso!
Ill post back my results when all of the necessary hardware has arrived and I've managed to dump the contents of the EEPROM!
Thank you all for your help with this!
