Page 13 of 15 FirstFirst ... 389101112131415 LastLast
Results 181 to 195 of 218
  1. #181
    ray-ray's Avatar
    Basic has a different hardware component (software is the same) can not handle GM stuff.. they can not figure the issue out.
  2. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    narkeleptk (21st November, 2019), ranchero (21st November, 2019)
  3. #182
    Sep 2016
    Its able to do Mitsubishi Outlander 2014 and up akl? Smartkey and regular key? Till when it works?
  4. #183
    Nov 2018
    Quote Originally Posted by ray-ray View Post
    I read they just did a recall on the basic saying the processing chip is defective and that's the problem with b111 systems. They're replacing the chip free via Locklabs
  5. The Following 2 Users Say Thank You to milehighlockdoc For This Useful Post:
    darknezz19 (25th November, 2019), narkeleptk (21st November, 2019)
  6. #184
    Nov 2013
    Wow. That's very good to know. Thanks.. Do you know if precode adapter will work with basic version?
    Quote Originally Posted by milehighlockdoc View Post
    Do you mind to share the link about this recall?
  7. #185
    Nov 2013
    2013 Scion FRS - remote programmed under "Toyota - remote - Type 2". Customer only had valet key, G-chip, for me it was easier just copy his chip instead of trying to program master key.
  8. #186
    Nov 2013
    2015 Dodge RAM 1500 smart key - FAIL. iKey820 pulls PIN, then asks to turn hazards on, then communicates, asks to place smart key close to start button and press unlock once, then "communicating" -- "failure". Tried under RAM, RAM 1500, RAM 2500.
    BTW when tried to do it with SKP900 - same thing. Can't check if PIN pulled correctly by iKey820 because SKP900 can't pull PIN on this truck.
  9. #187
    narkeleptk's Avatar
    May 2017
    USA
    Quote Originally Posted by ranchero View Post
    You sure you had the right key & it was unlocked?
  10. The Following User Says Thank You to narkeleptk For This Useful Post:
    darknezz19 (28th November, 2019)
  11. #188
    Nov 2013
    Quote Originally Posted by narkeleptk View Post
    One key was unknown China (supplied by customer), it was unlocked. No luck. Another was mine, original unlocked, but I found later that I forgot to install battery in it. So next time I will try again.
    2004 Jaguar XJ8. Key added fine (only one option on the screen - all keys lost, minimum 2 keys required). Add remote - fail, even though process goes as it should (I think iKey has menu for exact 2004 XJ8 model remote). Recognizes both original and new remotes, communicates and tells "success" at the end. Result - old remote still works, new - does not. Tried few times, no luck. SKP-900 does same thing - shows "success" but remote not added. SBB doesn't have Jaguar in REMOTE menu. I added remote manually at the end, but not all older cars have that option. Still looking for tool which works fine with remotes for older Chryslers, Jaguars, Land Rovers (late 90's - early 00's). Any hint?
  12. The Following User Says Thank You to ranchero For This Useful Post:
  13. #189
    Jan 2012
    N.Y. U.S.A.
    2002 Honda Civic
    Add key had a communication error, got it done using Accord for same year.
    2004 Acura MDX
    AKL programmed OK.
    2007 Lexus RX350
    AKL failed to communicate after final procedure where you need to turn key on/off 5 times. I had to disconnect the car battery and reconnect to have it communicate again, this time ending with the key in the on position during the final procedure and it programmed OK.
  14. #190
    camelgd's Avatar
    Jan 2011
    South Illinois
    Add a proxy key 2013 Prius, no problems.
  15. The Following User Says Thank You to camelgd For This Useful Post:
    narkeleptk (6th December, 2019)
  16. #191
    narkeleptk's Avatar
    May 2017
    USA
    No key programming options for early model X-type & S-type Jaguars. Only remote.
  17. #192
    Apr 2015
    Received mine yesterday , today first job renault kangoo 2003 with remote key id 46 to add key , reading pincode failed type 1 and 2 . the vehicle is listed job done with other tool
  18. #193
    Apr 2015
    Infinity g37 2010 add key i mn job with ikey 820 success
  19. #194
    Jan 2017
    USA ����
    Autek ikey820
    2018 rogue used 2017 rogue in menu success in 30 secs
    Usa add 2 key 434mhz 4 button
    Obdstar x300 dp has 2017-19 in menu but it failed(at least it warned about bad bcm id numbers and gave cars current id
  20. The Following User Says Thank You to sleepyrz For This Useful Post:
    ranchero (10th January, 2020)
  21. #195
    ray-ray's Avatar
    Warning was put on by me on the AutoProPad >>pass it on to Obdstar.
