Page 5 of 15 FirstFirst 12345678910 ... LastLast
Results 61 to 75 of 218
  1. #61
    Jun 2017
    US
    Nice list, lots of good stuff in there! Where did this info come from btw sleepyrz?
    Ford Mustang 1999
    Parameter Reset for cluster change, 10 min wait, said okay. Delete stored keys and add back original key and 2nd key after maybe 8 mins. Started up.
    OKAY
    Dodge Ram 2500 Diesel 2018
    Couldn't read PIN, tried a bunch of different years under RAM 2500 RAM and Superduty. Dealer closed today thought it would pull dang.
    FAIL on PIN read
  2. #62
    Jan 2017
    USA ����
    Quote Originally Posted by darknezz19 View Post
    Ford Mustang 1999
    OKAY
    FAIL on PIN read
    2018 is new and different
    Go here and read
    http://www.digital-kaos.co.uk/forums...ing-key-bypass
  3. #63
    Jun 2017
    US
    2010 Ford Fusion AKL
    Programmed fine after 10 min wait. Even MVP has no bypass 10 min wait on this one.
    OKAY
    2012 Chevy Malibu AKL
    Failed to communicate. Tried 2009 and 2011 as well, no communication. Surprisingly communicated and programmed fine with CK200, first car Ikey 820 has failed me on.
    FAIL
  4. #64
    Jan 2017
    USA ����
    weird i did a 2012 no problem........
  5. #65
    Jan 2017
    USA ����
    also there is a very veeerrrrry small update
    something about ford fiesta programming and fixing software bugs or firmware bugs
    here read
    http://www.autektools.com/Common/201...926164939.html
  6. #66
    Jan 2012
    N.Y. U.S.A.
    2016 Toyota Camry - Programmed "H" transponder and RKE separately, both successful.
    2004 Infiniti QX56 - Automatically converted BCM and displayed old & new pin codes, added 2 keys successfully.
  7. #67
    Jan 2017
    USA ����
    Quote Originally Posted by pakrat70 View Post
    that is for add keys correct not an AKL
  8. The Following User Says Thank You to sleepyrz For This Useful Post:
    michaeleschmidt (14th October, 2018)
  9. #68
    Jan 2012
    N.Y. U.S.A.
    Quote Originally Posted by sleepyrz View Post
    Correct! This was for adding keys, not AKL. Sorry about that...
  10. #69
    Jun 2017
    US
    2003 Accord AKL
    Added key quick, no 1-2 minute wait like on skp900
    OKAY
    2007 Escalade AKL
    First communication step worked but then no communication when trying to program key. Finished up with CK200.
    FAIL
    2014 Chevy Cruze AKL
    Worked a treat, read pin and programmed key, seemed like longer than 10 minute wait though.
    OKAY
  11. #70
    Canada
    Hi DK,i just receive my Autek iKey 820 Super OBD Key Programmer for me i have 500 tokens but no user manual so i have a question about this tool i want to know in the tool setting what is the default setting contrast level,thanks in advance.
  12. #71
    Jan 2012
    N.Y. U.S.A.
    2004 Ford Explorer - Added a key in less than 5 seconds!
  13. #72
    Jan 2012
    N.Y. U.S.A.
    Quote Originally Posted by starmobile View Post
    Mine says 192 for brightness.
  14. The Following User Says Thank You to pakrat70 For This Useful Post:
    starmobile (19th October, 2018)
  15. #73
    Jan 2017
    USA ����
    2010 f150 key added in 5 seconds
  16. The Following User Says Thank You to sleepyrz For This Useful Post:
  17. #74
    Jan 2012
    N.Y. U.S.A.
    2002 Toyota Solara - Added 2 keys successfully.
  18. #75
    Jan 2017
    USA ����
    2005 dodge magnum erased all keys and programmed in 3 new keys and one old key SUCCESS and a little bit of a story
    selected by model and year
    strange glitch tho
    i programmed in 1 new key
    key count 3
    customer then advises one key was stolen previously
    I had left in one old decrepit barely working thing of a key she had and there was also the previously stolen key left in as well...............
    so i offered to erase them all and reprogram back in the 2 keys
    NOW at this point she lets me know of two other keys she has inside that are already cut! but have not been programmed in................................
    so i now go and erase all the keys and am going to program in all 4 keys! i currently have in my hand
    erase keys goes fine
    key count 0
    go to add my new key i made her under NEW KEY ADDING
    success!
    key count 0..................
    uh oh thats not good
    add key trying with one of her new keys under NEW KEY ADDING
    success!
    key count 0....................
    grrrrrr this is bad
    hmmm let me try add with OLD KEY ADDING
    success!
    key count 1
    woooo
    key count 2 OLD KEY ADDING
    key count 3 OLD KEY ADDING
    key count 4 OLD KEY ADDING
    success!
    and so i think for some reason after i erased the keys
    only OLD KEY ADDING works even if they are completely new keys that had never been programmed in
    because the two keys she brought from inside the house had never been programmed in and when trying to add them after the erase
    it would only add them with OLD KEY ADDING
  19. The Following User Says Thank You to sleepyrz For This Useful Post:
    HeXeN (7th November, 2018)
