Page 11 of 15 FirstFirst ... 6789101112131415 LastLast
Results 151 to 165 of 218
  1. #151
    Jan 2017
    USA ����
    Mazda 3 2017 USA add a key
    X300 DP turn on wait seven minutes horn sounds twice
    wrong pincode FAIL
    Autek ikey820 does not have Mazda 3 2017 in menu semi-fail???
    BUT just use atenza 17+
    Program key turn on off with both SUCCESS
    The thanks button is HERE looks like this --->>> THANKS
  2. The Following User Says Thank You to sleepyrz For This Useful Post:
    narkeleptk (28th June, 2019)
  3. #152
    Jan 2012
    N.Y. U.S.A.
    2002 Honda Civic
    AKL programmed OK
    2012 Nissan NV2500
    Add key OK
  4. #153
    Jan 2017
    USA ����
    2015 altima USA AKL
    program key in about 30 seconds SUCCESS
    2008 tahoe add remote 10 seconds success
  5. #154
    narkeleptk's Avatar
    May 2017
    USA
    AKL on a 2010 TL prox system . No problems.
  6. #155
    Jun 2017
    US
    Tried a 2018 Fusion add prox with paid update. Gave me pincode error on 5 min wait screen.
  7. #156
    Jan 2012
    N.Y. U.S.A.
    2015 Infiniti QX50
    Failed to communicate, Smartbox got it done.
    2010 Toyota Corolla
    Add key OK
    2011 Jeep Wrangler
    Pulled pin and added remote key OK
  8. #157
    camelgd's Avatar
    Jan 2011
    South Illinois
    2004 Lincoln Aviator- programmed after 10 minute security.
  9. #158
    narkeleptk's Avatar
    May 2017
    USA
    2002 Cadi Deville .. NO Key options only remote....
  10. #159
    Jan 2012
    N.Y. U.S.A.
    2004 Lexus ES300
    AKL programmed quickly.
    2003 Nissan Murano
    Failed to communicate, got it done with a CK100
  11. #160
    Jun 2017
    US
    2013 Subaru Legacy AKL. Clenched butt cheeks and prayed Autek didn't get G protocol mixed into this year. Success.
  12. #161
    Jun 2018
    Anybody tried to pull pin code on 2016 Dodge Charger?. Mine didn't work.
  13. #162
    Jun 2018
    narkeleptk
    Just cut the key and start the car. There is no chip for 2002 Cadillac Deville, that's why you don't have Key Programming option.
  14. #163
    narkeleptk's Avatar
    May 2017
    USA
    Quote Originally Posted by alsa75 View Post
    narkeleptk
    Negative, 02 Cadillac Deville's here in the states use pk3 with megamos 13 chip.
  15. #164
    Jun 2018
    Quote Originally Posted by narkeleptk View Post
    Now I'm confuse of what cadillac I did cut the key and just started the car. I did couple of Cadillacs.
    Yes, you right, just checked the spreadsheet of the Chip that I have, and it says that that cadillac deville uses pk3 with megamos 13 chip.
    But my question is, why iKey have no option of key programming. I think that the option is in 2003 or 2004. You made me confuse now. I have to check the ikey programmer.
  16. #165
    Apr 2010
    Can do the self learning on early pk3. 3x10min procedure
    Sent from my SM-G960W using Tapatalk
