Results 1 to 15 of 15
    Jun 2013
    EU
    Default Ducato edc16c39 FAP problem. Need help.
    Hello.
    Have a problem with a Ducato van, tried many options to remove fap but none seems to work 100%
    Van comes back after some days with fap light on on cluster, and ash counter keeps increasing. Reseting ash level solves problem untill next week and van comes again "asking for a fap change".
    Attached original and swiftec file.
    Can anyone make good working file please.
    Ignasvw's Avatar
    Feb 2016
    Lithuania
    This solution is completle wrong. Swiftec also says that you need to remove sensors
    Chiptunning / EGR / DPF / FAP / DTC / FLAPS / Adblue / ETC.... CUSTOM SERVICE / FILE SERVICE / 24/7 Support
    Jun 2013
    EU
    Yes, i know it is wrong. Ash counter keeps increasing. But i don't have good manual solution in my base, that is why i ask for help
    Regards,
    Sep 2016
    what dtc you have?
    FILE SERVICE
    Jun 2013
    EU
    No dtcs, just fap light on dash.
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    soot still growing..
    i post solution for you tomorrow bro.
    have a good night now!
    DSG TUNING
    File Service
  7. The Following User Says Thank You to maajkii For This Useful Post:
    morgano (6th February, 2018)
    Sep 2016
    try my solution
    FILE SERVICE
  9. The Following 2 Users Say Thank You to voltechcar For This Useful Post:
    AVDigitale (17th April, 2018), morgano (6th February, 2018)
  10. #8
    Jun 2013
    EU
    @voltechcar
    Thanks mate, van is gone and not came back, so complete success.
    Thanks once more
  11. #9
    Sep 2016
    FILE SERVICE
  12. #10
    Jun 2013
    EU
    Van owner called again, voltechcar file lasted more than all previous tries, but again fap light on and limp mode.
    Not yet arrived and not diag data yet, i assume soot still growing but slower with this last file.
    More news to come when van arrive (again)
  13. #11
    johak's Avatar
    one more solution
  14. The Following User Says Thank You to johak For This Useful Post:
    morgano (17th April, 2018)
  15. #12
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    try and this and report pass in PM!
    reset dpf soot and calculate chks before write
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
  16. The Following User Says Thank You to AVDigitale For This Useful Post:
    morgano (18th April, 2018)
  17. #13
    Sep 2016
    use diagnostic tester and check differential pressure sensor on my file
    FILE SERVICE
  18. The Following User Says Thank You to voltechcar For This Useful Post:
  19. #14
    Jun 2013
    EU
    Quote Originally Posted by voltechcar View Post
    As soon as van arrives diagnose seesion will be first move
    To the others, thank you guys. This van revealed as a nightmare, even it was presumably easy thing from the begining.
  20. The Following User Says Thank You to morgano For This Useful Post:
    maajkii (18th April, 2018)
  21. #15
    Sep 2016
    my solution v2, disconnect all sensor from dpf, 2 temp sensor you have from dpf and 3 turbo temperature and of course differential pressure sensor. Write and report
    FILE SERVICE
  22. The Following User Says Thank You to voltechcar For This Useful Post:
    morgano (19th April, 2018)
