Results 1 to 8 of 8
    Jan 2018
    Default Nissan Sentra 2005 - 93c66 - Getting wrong mileage after correction.
    I want to write 117095 it read 171010.
    I used the Tachosoft Calculator, but I guess it is wrong.
    What are the lines to edit in this dump file?
    Thanks in advance.
    here is your file
    Jan 2018
    May I know what software do you used?
    Tacho Calculator gives the wrong lines. I have tried in 2 different Sentra, same year, and always read 600K.
    Please.
    wincalc ok for serious work
    Jan 2018
    I do no want to bother, but let me know if you can help me with the follow.
    I wrote the code to the chip. Then I read it again to check if updated correctly.
    Then I soldered back to the cluster, and read again 600K. I re-read the eeprom and now the data is different.
    I am using a Digimaster 3 to write the eeprom, I have used it before with others chips and so far I have not had any problem.
    Thoughts?
    Excuse my English.
    unsolder eeprom
    and use a good programmer
    1. upa
    2. orange
    Jan 2018
    There is chance that the DigiMaster 3 is writing incorrectly the eeprom?
    This only have happened to me twice, with the same car model and the same eeprom. No matter what I do, I even used the Tachosoft to write 10K miles to check what it write and it only change by some numbers.
    Not sure if I am explaining correctly.
    I appreciate your reply very much.
    Jan 2018
    Miniprog can do the job? With a good clip adapter? In circuit
