Cmd and some others tool do this problem,galletto in jtag mode is the best for this type of ecu
Sent from my SM-N910P using Tapatalk
Hello, yesterday i managed to kill dcm 3.5 via obd. genuine cmd failed... CMD did vread, i writed file with dpf off mod, and after that no connection with ecu. Cmd says " no data from ecu. Kess says " cant identify chasis " or smth.. I tried to write ori (vread) file Usprog, but no luck. THen i readed ecu. I saw that cmd missed all MAPs zone. Now i have galleto, i can read write with jtag. Ori vread file is 3.072Mb size, galleto read 3.073Mb. I can write cmd readed file with galleto, because i get error. I tried a lot of solutions, but none of them cant bring my ecu back to life. I attach ori cmd read, then usprog read after cmd crashed, and then file that i readed with galleto. Maybe someone had this issue in past. Or someone have ori file readed with jtag pinout.
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
Ignasvw (7th February, 2018)
I have done with kess dcm3.5 only OBD, and till now no Problem , i mean Ford delphi dcm 3.5 , normal file from kess has 3.5 mb , if it help I can send you ori file one read with kess , and I think I have mpps also, 140 and 163 hp , if you need I will post file !
Trimis de pe al meu SM-G930F folosind Tapatalk
KESS has no problem with Read/Write DCM3.5 Ford via OBD. Even on 12.3-12.5V.
the problem is probably the wrong checksum
if you want to try this with galleto
Somtimes shit happend , i hope you can bring ecu back to life, recovery from CMD ??? You have to report this to cmd , they can help you , call support cmd!
Was worth trying
Is problem solved? Maybe try with Abrites to flash ori?
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
