Where did you buy it from
Sent from my SM-G935F using Tapatalk
Hi , i have 7020 ktag
when i read ecu it do 2 files , encrypted and decrypted
when i write back file it accept just encrypted file, so i do change on file that is not encrypted, but i cant write them back
is there some sw to encrypted and decrypted files ?
absolutely unless device this Ktag
its from china,
What car year make model engine etc
Maybe checksum issue. You must install MSVC redistributables.
And take a photo with your error.
Post screenshot, 1 file is for backup bdm/tricore ALL.
Or disable restore and write eeprom+flash (+maps) manual
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
its Mitsubishi ecu 1860A318 E6T41779
i use E6T348xx (P260?) protocol
its read two files , but when i will write back its accept only encrypted , its write it with no problem
decrypted file give wrong file type error
that all, i do no how to write back edited file that is not encrypted
files attached
its work like slave unit, accept just encrypted
