Results 1 to 5 of 5
    Nov 2011
    Usa
    Default vw amarok
    Hello friends, could someone help me with a solution for egr and dpf off
    amarok edc17c54
    solved
    Attachment 505347
    Dec 2015
    your file is changed or is not well read plus the cheksum is not well .. post the original or make a correct reading
    Feb 2017
    Default Dpfoff egr off amarok
    Here is your file!I think its ok!
    Do not disconnect sensors and dont forget chksum.
    best regards
  4. The Following User Says Thank You to olds 454 For This Useful Post:
    ISABINO (8th February, 2018)
    sdtsedat's Avatar
    Jan 2015
    Belgium
    How did you read ecu?
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
    Member trivilin8's Avatar
    Mexico
    Hello, I need to match a similar ecu, could you tell me what tool did you use to read the ecu? And if it’s not too much to ask what do you use to get pin, CS MAC from dump. I am struggling too trying to flash it to another calibration, I’m trying with erWin but I’m not sure if it could be done, it would be awesome to know before paying a subscription
