Results 1 to 14 of 14
    P&D's Avatar
    Default Looks like VM have pulled the plug out
    looks like VM have decided to end free tv in HD no main HD channels clearing
    on 2 different ----'s
    the rest are still open.....anyone else got problems
    Have VM flicked the switch ?
    I'm in the Liverpool area......anyone else off
    digicon's Avatar
    Lots of Area's Gone from what i can see, Enjoy the SD while you can
  3. The Following 2 Users Say Thank You to digicon For This Useful Post:
    P&D (10th February, 2018), super jumbe (13th April, 2018)
    happy_highlander's Avatar
    Aug 2010
    Only seems to be sports HD in Northants that's gone
    Sent from my SM-G935F using Tapatalk
    joe516's Avatar
    Mar 2008
    manchester
    Quote Originally Posted by happy_highlander View Post
    Yep a few areas now have lost them
    information given is to be used for educational purposes only
    Don't Forget To Say Thanks If You Like My Post
    IF YOU THINK A POST HAS BEEN USEFUL USE THE THANKS BUTTON
    If It Ain't Broke Don't Fix It
    plasterer's Avatar
    Jun 2008
    Mersyside
    Same here Liverpool.
    S s mix sports H D clear
    All movies ok.
    But main sport blank after running auto bowk......paul
    PAUL
    DK Veteran lincsat's Avatar
    Jun 2008
    VM announced last Year that Sky Sports HD channels would only be on TiVo type boxes only after Jan this Year. Other HD channels and Sports News & Mix HD are all OK
  8. The Following User Says Thank You to lincsat For This Useful Post:
    xOxOx (16th February, 2018)
  9. #7
    Usa
    yep mine as well
  10. #8
    DK Veteran chris31560's Avatar
    wigan
    could this be the end like sly?..
    A LITTLE THANX GOES A LONG WAY
  11. #9
    Jun 2008
    Quote Originally Posted by chris31560 View Post
    Eventually they will all change, there have been no more announcements from VM but they have only supplied the TiVo box to subscribers for over a Year.
  12. The Following User Says Thank You to lincsat For This Useful Post:
    chris31560 (17th February, 2018)
  13. #10
    Apr 2011
    I'm in Merseyside area all OK.... For now that is
  14. #11
    Sep 2008
    in ltn hd sports gone
  15. #12
    joe516's Avatar
    Mar 2008
    manchester
    I can confirm Manchester 41060 has gone
  16. #13
    People should realise it doesn't matter where you are if the channels go off. It's where the box from which the Card came that matters. Unless of course it's an original box you are talking about. IE a Real Virgin box.
  17. #14
    Jun 2008
    Not in this case. The 1841 CaID got switched off in the data stream sent in the local area, it would still have been active on the cards. It happened in Leicester first (late last Year) and then was staggered in other areas.
  18. The Following User Says Thank You to lincsat For This Useful Post:
    plasterer (20th March, 2018)
