Octavia Mk1 Rs 1.8T - AUQ with FMIC, DP, K03s, - SAI,N249,N112,EGR - remove.
I install a set of 380cc (BAM injectors) + a 4bar FPR. I know i have to calculate KRKTE, TEMIN, TVUB and KVB. Values for TVUB copied from BAM file.
Can someone help me out ? Thank you
BAM have 380 with 3bar FPR, 380 @ 4bar = 420 or 440 ? I'm wrong ?
Apsik, you're fast, thank you. I want to post my file, how can i do that ?
In this file a have a error of B1 S1 - Open circuit and Performance too low, only with this file !
No, with my other tuning file, its ok ... i think something it's wrong in that file. https://files.fm/u/jma2ttjr
Can you post both files?
Maybe you have DTC OFF
If you find my post helpful please hit Thanks button.
You can also hit Reputation button if you are kind enough.
https://files.fm/f/3xvpuu8h the other file
nothing ? help please
your new flow it is 440cc,
B1 S1 is primary O2 so you must repair it to work the car ok.
I can't download any of your files
Apsik try now, here are the 2 files ! https://files.fm/u/vc93p24n
Wrong AFR- too much fuel
How do you manage timing? Did you make some logs?
How it s lambda at wot?
Too much boost! ( I don t think can handle 1,5 bar after 5500rpm!)
