Page 4 of 7 FirstFirst 1234567 LastLast
Results 46 to 60 of 105
  1. #46
    Dec 2018
    Quote Originally Posted by r-parts View Post
    Here are some more dumps with different km's
    i tested in red and blue display, 125cc and 50 cc.
    no problem at all.
    i'm making more low km files but it takes time
    no pass, please rep
    btw smok pinout:
    Attachment 580084
    Thanx🙂 what kind of licence you need from smok?
  2. #47
    Nicolas9's Avatar
    Feb 2017
    Aruba
    i just did.
    works perfect, DATAflash ext don't determine the max speed, flash does.
    only the max pulse for upa is 0,151 for 50cc dash
    I don't know if you don't understand me, or I don't understand you.
    Anyway, I used smok dataflash to put a 150cc file on a 50cc dashboard, but then if I drive 50kmh, it shows 30kmh on the dashboard instead of 50kmh...
  3. #48
    it's rl78 licence
  4. #49
    I tested here today with 2 tacho's, but all readings are correct so far correct.
  5. #50
    Nicolas9's Avatar
    Feb 2017
    Aruba
    can vvdi prog read this mcu?
  6. #51
    gogalv's Avatar
    Aug 2010
    Orange 5 !
    You'll need pictures from all sides mate .... ? PremierD
  7. #52
    drpeter's Avatar
    The Netherlands
    Quote Originally Posted by Nicolas9 View Post
    No only write.
  8. The Following User Says Thank You to drpeter For This Useful Post:
    Nicolas9 (1st March, 2019)
  9. #53
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Quote Originally Posted by drpeter View Post
    No only write.
    thnx.
    can you tell me which option i have to use for writing?
    i think ..data 8kb read?
    thnx
  10. #54
    drpeter's Avatar
    The Netherlands
    thnx.
    thnx
    this option
  11. The Following User Says Thank You to drpeter For This Useful Post:
  12. #55
    May 2011
    hi
    this mcu read write option available with vvdi prog,smok orange 5 ...only these 3 or any other cheap solution also....???
  13. #56
    Nicolas9's Avatar
    Feb 2017
    Aruba
    this option
    Hi.
    I tried writing with vvdi prog, but it destroyed the MCU.
    I connected orange wire to pin 5(tool0), and yellow to pin8 (reset). This is correct? (I have VCC/gnd 100% correct).
    I tried to program but didn't work. Then try again and no connection and dash is dead.
    Do I have to do anything with the security bytes?
    I used smok on these clusters, work perfect..
    Thnx a lot.
  14. #57
    drpeter's Avatar
    The Netherlands
    Hi.
    Thnx a lot.
    I made 2 last month with vvdi no problem. Strange i dont know what you did wrong. Sec bytes not needed.
  15. The Following User Says Thank You to drpeter For This Useful Post:
    Nicolas9 (16th March, 2019)
  16. #58
    Jul 2016
    where buy solution (script) for vespa primavera for orange 5? Sorry for my bad english.
  17. #59
    gogalv's Avatar
    Aug 2010
    RL78/D1A R5F10xxx EEprom Read / Write / Verify need to buy from Pavel pervomaysk
    The DASH of the calculation I have.
  18. The Following User Says Thank You to gogalv For This Useful Post:
    dobribg (5th November, 2019)
  19. #60
    Oct 2016
    Default Primevera 150
    Hello
    can someone help me for RL78
    orginal 6728 km need 23500 km
