Page 2 of 7 FirstFirst 1234567 LastLast
Results 16 to 30 of 105
  1. #16
    sv2hqx's Avatar
    Jun 2014
    Quote Originally Posted by robrkl View Post
    Anyone have connections to power up this dash?
    Send pic of connector
  2. #17
    Nov 2015
  3. #18
    Mar 2016
    Here you are
    Quote Originally Posted by sv2hqx View Post
  4. The Following User Says Thank You to slawo1z For This Useful Post:
    skens (21st April, 2022)
  5. #19
    Nov 2015
    Quote Originally Posted by slawo1z View Post
    Here you are
    Wont start up with this connections
  6. #20
    Mar 2016
    MUST WORK
    I power on 6pcs dashboard vespa
    3 whit abs
    3 whitout abs
    I have 6 dataflash readings
    if you dash show the same as in the picture
    you erase flash !!!!!!! you have a big problem
    remember disconect prog when power on
    I do not have a password for this cpu yet
  7. The Following User Says Thank You to slawo1z For This Useful Post:
    Diagcar1 (6th August, 2018)
  8. #21
    sv2hqx's Avatar
    Jun 2014
    first pin need power too
  9. The Following 5 Users Say Thank You to sv2hqx For This Useful Post:
    dashradio (11th December, 2018), Diagcar1 (6th August, 2018), Nicolas9 (4th September, 2018), robrkl (6th August, 2018), skens (21st April, 2022)
  10. #22
    Nov 2015
    Thanks, needed that extra 12V.
  11. #23
    Nov 2009
    just write DATAFLASH with smok with one of these dumps.
    First read DATAFLASH and save.
    Dash will be dead now but no worry.
    When you write your backup back it works again.
    Then open a dump with correct km's and write.
    job done.
    As far as i know there's no different between abs version and no abs.
    for 50cc i'm not sure the dumps are the same.
    This is what i have right now but i'm making more dumps as the come along.
    I'm letting one dash count with tacho pulse and take backups along the way.
  12. The Following 5 Users Say Thank You to r-parts For This Useful Post:
    dashradio (11th December, 2018), didi_du_93000 (18th June, 2021), gijsvm (16th September, 2018), Nicolas9 (26th August, 2018), sv2hqx (26th August, 2018)
  13. #24
    Nov 2009
    if someone can try on 50cc and confirm.
    Nothing to loose here, since you make a backup first!!
  14. The Following User Says Thank You to r-parts For This Useful Post:
  15. #25
    Feb 2016
    Can you tell me what tools i need to buy from smok to do the job?
    Then i can test and send you low km dumps also. I have a lot of 50cc clocks with low kms.
  16. #26
    Nov 2009
    i use jtag tool from smok, thats it.
    and for speedo pulse i use upa usb pulse generator set to 0.166 maximun
  17. The Following 2 Users Say Thank You to r-parts For This Useful Post:
    jaed (1st October, 2018), Nicolas9 (1st September, 2018)
  18. #27
    Feb 2016
    Ok, thanks i will order this products.
    I have 15 vespa km clock with low km.
    I was looking a long time for this solution. If it works i can send you low km dumps also.
  19. The Following User Says Thank You to jaed For This Useful Post:
    Nicolas9 (2nd September, 2018)
  20. #28
    Nicolas9's Avatar
    Feb 2017
    Aruba
    anyone could share some 50cc dump files?
    thnx
  21. #29
    Nicolas9's Avatar
    Feb 2017
    Aruba
    could someone change this file to 2750 km?
    (original 5168km)
    thnx a lot
  22. #30
    Dec 2010
    vietnam
    Quote Originally Posted by Nicolas9 View Post
    (original 5168km)
    thnx a lot
    2750km vespa!!!
  23. The Following User Says Thank You to hoangtu For This Useful Post:
    Nicolas9 (16th September, 2018)
