Results 1 to 13 of 13
Thread: Audi a3
    Default Audi a3
    62 reg. 1.4tfsi. Petrol. Have a fault code of p2263 turbocharger supercharger boost system performance. Engine light on and Epc light. I have changed turbo actuator and boost map sensor,but fault still there. Checked pipes and turbo,all seems fine. Anyone had this problem before.
    in live data boost map sensor has a actual and specified.
    on idle specified reading is about 300 but the actual is about 900.
    Is this correct.i have changed boost map sensor but still the same.
    Oct 2012
    London
    End position of wastegate should read 850-900Mbar, remove vacuum hose on turbo and manually test movement with vacuum pump, these seize up. Audi have repair kit available 03C 198 722.
    There is no vacuum hose on this turbo, it's electronic. I fitted a new electronic turbo actuator, but still the same. Can anyone help
    Jul 2013
    yorkshire
    What tool are you reading this with? Actual and specific should be same not x3. Does this have boost sensor AND map sensor? If so with ign on engine off they should read the same a/pressure.
  5. The Following User Says Thank You to autoden For This Useful Post:
    radiosolutions (16th February, 2018)
    Feb 2016
    sveden
    Mislim da ovaj auto ima 2 senzora karte check both
    Yes it has map and boost sensors, but I have changed both, but fault still there using original vagcom .
    Jul 2013
    yorkshire
    OK you have both, now answer the question in live data. Do they read the same? They should only read sea level pressure. Come on mate this is schoolboy stuff.
    here is a full scan of the car, if someone could help.
    VIN: WAUZZZ8V4DA026258 License Plate: WD62BPX
    Mileage: 144433km-89746mi Repair Order: rj wayne
    Chassis Type: 8V-AU37 (5Q0)
    Scan: 01 03 08 09 10 15 16 17 19 42 44 52 55 5F
    VIN: WAUZZZ8V4DA026258 Mileage: 144433km-89746miles
    01-Engine -- Status: Malfunction 0010
    03-ABS Brakes -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: Malfunction 0010
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    Address 01: Engine (J623-CMBA) Labels:. 04E-907-309-V1.clb
    Part No SW: 04E 906 016 J HW: 04E 907 309 A
    Component: 1.4l R4 TSI H08 4908
    Revision: WAH08---
    Coding: 02190032230401082000
    Shop #: WSC 06314 790 00021
    ASAM Dataset: EV_ECM14TFS01104E906016J 002009
    ROD: EV_ECM14TFS01104E906016DE_AU37.rod
    VCID: 29592C01485F0C0EE6-807C
    1 Fault Found:
    19404 - Turbo/Super Charger Boost System
    P2263 00 [036] - Performance
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 144433 km
    Date: 2018.02.12
    Time: 16:07:59
    Engine speed: 1145.50 /min
    Normed load value: 11.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 30 °C
    Intake air temperature: 12 °C
    Ambient air pressure: 990 mbar
    Voltage terminal 30: 11.520 V
    Unlearning counter according OBD: 40
    Charge pressure actuator: specified position: 140.00 %
    Bypass valve f high press turboch turbine inlet: actual value: 101.03 %
    Charge pressure actuator: adaptation for lower stop: 4466.8 mV
    Bypass valve for high press turbocharger turbine inlet: status-Bit 0: 0
    Bypass valve for high press turbocharger turbine inlet: status-Bit 16: 0
    Bypass valve for high press turbocharger turbine inlet: status-Bit 24: 55
    Bypass valve for high press turbocharger turbine inlet: status-Bit 8: 66
    Bypass valve for high press turboch turbine inlet: uncond volt: 4614.0 mV
    Charge air pressure: actual value: 994.84 hPa
    Readiness: 1110 0001
    Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
    Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
    Component: ESC H75 0437
    Revision: 00000000 Serial number:
    Coding: 10F18AA220222A720179060501CB290851045480608094F200 39000805
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 008020
    ROD: EV_Brake1UDSContiMK100IPB_008.rod
    VCID: 7DF12851EC5740AEFA-8028
    No fault code found.
    Address 08: Auto HVAC (E87) Labels:| 8V0-820-043.clb
    Part No SW: 8V0 820 043 A HW: 8V0 820 043 A
    Component: AC Automat H11 0031
    Revision: 20019000 Serial number: 00000000029208
    Coding: 00100004000000011000000000001100
    ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
    ROD: EV_AirCondiFrontVaAU37X.rod
    VCID: 306FC1656B857DC621-8064
    Relative humidity sensor in fresh air intake duct:
    Subsystem 1 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: CF280166000000000001
    Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb
    Part No SW: 5Q0 937 084 Q HW: 5Q0 937 084 Q
    Component: BCM MQBAB H H14 0106
    Serial number: 00011301001102
    Coding: 07000A46C20120DD03044000B31C07A8000000000000000000 0000000000
    ASAM Dataset: EV_BCMCONTI 010001
    ROD: EV_BCMBOSCH_010.rod
    VCID: 468387BDF901C376EB-8012
    Control Unit For Wiper Motor:
    Subsystem 1 - Part No SW: 8V2 955 119 A HW: 8V2 955 119 Labels: 5QX-955-119-V1.CLB
    Component: WWS370 121121 041 0580
    Serial number: 121210011852
    Coding: 0A47F7
    Light switch:
    Subsystem 2 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
    Component: E1 - LDS MQB H05 0032
    Serial number: 19 08 2012 00000311
    Sensor For Anti Theft Alarm System:
    Subsystem 3 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
    Component: Sensor, DWA 005 0313
    Serial number: 000000000ZY123103H2Z
    Alarm horn:
    Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
    Component: Sirene, DWA 004 0311
    Serial number: 00000000000055256194
    Relative Air Humidity Interior Sender:
    Subsystem 5 - Part No SW: 8U0 955 559 HW: 8U0 955 559
    Component: G355_FeuchteS H07 0002
    Serial number: 20243734
    4 Faults Found:
    204290 - Remote key 1
    B1479 18 [009] - Current Too Low
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 248
    Mileage: 137076 km
    267030 - Siren / Alarm Horn for Anti-Theft Alarm System
    U1137 00 [008] - Implausible Message
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 3
    Reset counter: 156
    Mileage: 1048574 km
    Date: 2000.00.00
    Time: 00:00:00
    929806 - Light Switch
    B126A 04 [008] - Internal System Fault
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 157
    Mileage: 144418 km
    Date: 2018.01.30
    Time: 16:50:24
    930056 - Light Switch
    B126A 29 [008] - Signal Implausible
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 157
    Mileage: 144418 km
    Date: 2018.01.30
    Time: 16:50:24
    Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
    Part No SW: 5Q0 919 283 A HW: 5Q0 919 283
    Component: PARKHILFE 4K 009 0026
    Revision: -------- Serial number: 60831300414703
    Coding: 0000040001
    ASAM Dataset: EV_EPHVA14AU3700000 002015
    ROD: EV_EPHVA14AU3700000_002_AU37.rod
    VCID: 377DFA798EEBAAFE60-8062
    Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb
    Part No SW: 5Q0 959 655 L HW: 5Q0 959 655 L
    Component: AirbagVW20 009 0349
    Serial number: 003GER00L421
    Coding: 98CCC0000C0000005C5400CA00C800000065
    ASAM Dataset: EV_AirbaVW20SMEVW37X 002126
    ROD: EV_AirbaVW20SMEVW37X_VW37.rod
    VCID: 49998C81E81F2C0E06-801C
    Side Sensor Driver Front:
    Subsystem 1 - Part No SW: ----------- HW: 480 000 801 13
    Component: SideSensor_Df 001 0887
    Serial number: 357670000008327C7C0-
    Coding: 2D2D2D
    Side Sensor Passenger Front:
    Subsystem 2 - Part No SW: ----------- HW: 480 000 801 13
    Component: SideSensor_Pf 001 0887
    Serial number: 35867000000323B45C0Q
    Coding: 2D2D2D
    Side Sensor Driver Rear:
    Subsystem 3 - Part No SW: ----------- HW: 480 400 301 13
    Component: SideSensor_Dr 001 6149
    Serial number: 3516502C70CAF160528E
    Coding: 2D2D2D
    Side Sensor Passenger Rear:
    Subsystem 4 - Part No SW: ----------- HW: 480 400 301 13
    Component: SideSensor_Pr 001 6149
    Serial number: 3526502C70CAF16621EN
    Coding: 2D2D2D
    Front Sensor Driver:
    Subsystem 5 - Part No SW: ----------- HW: 480 402 711 12
    Component: FrontSensor_D 001 6149
    Serial number: 3556502B50D5D625E20G
    Coding: 2D2D2D
    Pedestrian Protection Driver:
    Subsystem 6 - Part No SW: ----------- HW: 480 401 112 12
    Component: PedP_Sensor_D 001 6149
    Serial number: 2286502BD0CAF164134J
    Coding: 2D2D2D
    Pedestrian Protection Passenger:
    Subsystem 7 - Part No SW: ----------- HW: 480 401 012 12
    Component: PedP_Sensor_P 001 6149
    Serial number: 2296502A70D464712273
    Coding: 2D2D2D
    Pedestrian Protection Center:
    Subsystem 8 - Part No SW: ----------- HW: 480 401 112 12
    Component: PedP_Sensor_C 001 6149
    Serial number: 2306502B30CAF16360ED
    Coding: 2D2D2D
    Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb
    Part No SW: 8V0 953 521 HW: 5Q0 953 549 A
    Component: Lenks. Modul 007 0070
    Revision: -------- Serial number: 04011308491507
    Coding: 8408
    ASAM Dataset: EV_SMLSKLOMQB 009001
    ROD: EV_SMLSKLOMQB_009_AU37.rod
    VCID: 77FD3A79CE6B6AFEA0-8022
    Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb
    Part No SW: 8V0 920 970 HW: 8V0 920 970
    Component: KOMBI H24 0570
    Coding: 278401002A8046000100E800000000
    ASAM Dataset: EV_DashBoardVDDMQBAB 008026
    ROD: EV_DashBoardVDDMQBAB_008_VW37.rod
    VCID: 79F93C41F87F7C8ED6-802C
    Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb
    Part No SW: 5Q0 907 530 J HW: 5Q0 907 530 F
    Component: GW MQB High 125 1126
    Revision: -------- Serial number: 0000259385
    Coding: 030100F42B0864005B000248080B0000000100000000000000 0000000000
    ASAM Dataset: EV_GatewLear 008010
    ROD: EV_GatewLear_008.rod
    VCID: 387FF94583F5A58669-806C
    Alternator:
    Multi Function Steering Wheel Control Module:
    Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
    Component: E221 - MFL H02 0014
    Serial number: 17 12 2012 A0137733
    Battery Monitoring Control Module:
    Subsystem 3 - Part No SW: 5Q0 915 181 D HW: 5Q0 915 181 D
    Component: J367-BDM H08 0192
    Serial number: 00000000002990777635
    Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb
    Part No SW: 5Q0 959 393 A HW: 5Q0 959 393
    Component: TSG FS 012 0006
    Serial number: 06121200010160
    Coding: 00100E204001040100001002
    ASAM Dataset: EV_DCUDriveSideEWMINKLO 006003
    ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
    VCID: 3D71E851ACD780AEBA-8068
    Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb
    Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
    Component: EPS_MQB_ZFLS 119 1021
    Coding: 81
    ASAM Dataset: EV_SteerAssisMQB 008022
    ROD: EV_SteerAssisMQB_008.rod
    Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb
    Part No SW: 5Q0 959 592 A HW: 5Q0 959 592 A
    Component: TSG BFS H12 0006
    Serial number: 16081200010774
    Coding: 001006204001040100001002
    Shop #: WSC 13459 000 1048576
    ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
    ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
    VCID: 3E73EF5DA1D19BB6A3-806A
    Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
    Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
    Component: LWR-ECU 005 0070
    Revision: -------- Serial number: --------------
    Coding: 019C000001000000
    ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
    ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
    VCID: 75E13071D46718EEB2-8020
    Address 5F: Information Electr. (J794) Labels:| 8V0-035-MIB-HGH1.clb
    Part No SW: 8V0 035 043 J HW: 8V0 035 043
    Component: MU-H-N-EU H40 0404
    Serial number: A039A0D7511866
    Coding: 01730001FF00000021110001000A00002F00010701000100DE
    Shop #: WSC 45315 001 1048576
    ASAM Dataset: EV_MUHig4CHBAS 001040
    ROD: EV_MUHig4CHBAS_AU37.rod
    Data medium:
    Subsystem 1 - Part No SW: V03 959 800 E HW: -----------
    Component: ECE 2012/13 --- 0028
    Serial number: --------------------
    Display unit 1 for multimedia system:
    Subsystem 2 - Part No SW: 8V0 919 604 A HW: 8V0 919 604 A
    Component: DU High H47 0014
    Serial number: AUZ8Z9CG1000MF
    Multimedia Operating Unit:
    Subsystem 3 - Part No SW: 8V0 919 614 R HW: 8V0 919 614 D
    Component: ControlUnit_H H64 0766
    Serial number: C1000002101200010165
    Compact Disc Database:
    Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote --- 1007
    1 Fault Found:
    6697 - Databus
    U1121 00 [008] - Missing Message
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 157
    Mileage: 139221 km
    Date: 2017.06.15
    Time: 12:50:50
    Voltage terminal 30: 13.4 V
    Network diagnosis-Status: Enabled
    End-------------------------(Elapsed Time: 03:41)--------------------------
  10. #9
    Dunker's Avatar
    Yorkshire
    Turbo pressure specified 300 / actual 900 and the actuator specified 140% / actual 101.03% so actuator not controlling turbo properly. Address 5F showing terminal 30 (B+) 13.4v at time of its own fault but address 01 showing 11.52v @ 1145.5 rpm. Maybe not enough lectric to ECU and / or actuator ? Wiring is like dental floss and the plugs look like they have come from China on these nails. 4.4v on lower stop as well?
    Over-priced German tat.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  11. The Following User Says Thank You to Dunker For This Useful Post:
    radiosolutions (20th February, 2018)
  12. #10
    Checked wiring to Ecu. All fine.battery voltage was low because battery faulty,I have changed this. I have tested map and turbo pressure sensor,with key off both read outside air, when running map reading 300 and turbo pressure sensor around 999 outside air. So sensors and wiring fine. Should the turbo pressure sensor be at 999 with engine running. If I accelerate in live data boost pressure goes from around 999 to 1100 ,very small change . Can anyone help.
    Why is boost pressure on idle around 1000 mbar
    need help on this car please
  13. #11
    Dunker's Avatar
    Yorkshire
    Sounds very strange to be fair. Tickover MAP you would expect to he 350mbar or somewhere there. Turbo not being controlled correctly or not being abled to be controlled how the ECU wants as far as we know. The specified 140% on the actuator and 101% actual would suggest the ECU is trying to throttle back the turbo because there is too much turbo pressure. Your turbo pressure at tickover is near atmospheric pressure and doesnt rise much away from atmospheric when boosting. Its like there is a hole in the inlet manifold. But you would obviously see that. Could it be like an EGR sticking open - although if it was bad EGR you would have thought it wouldnt run right. Can you use the diagnostic to make turbo actuator do a full swing (although that wouldn't explain 1 bar at tickover). Surely the 1 bar at tickover would be the first thing to solve. Where exactly are the two pressure sensors.
  14. The Following User Says Thank You to Dunker For This Useful Post:
    radiosolutions (28th February, 2018)
  15. #12
    Oct 2012
    London
    You say you fitted a new actuator (V465), there are 2 versions on these, 1 you need to adjust linkage to specified amount (spec through diag) and the other version just needs to be adapted in Engine controller. What version do you have?
  16. The Following 2 Users Say Thank You to rivalryan For This Useful Post:
    Dunker (27th February, 2018), radiosolutions (28th February, 2018)
  17. #13
    Actuator has to be adjusted. We have taken off the waste gate and there's quite a bit of play, and slightly sticky. Going to replace full turbo at request of customer.so I will let you no. Thanks for the help.
    How do you set new waste gate arm with the machine.
