0281011228 BDM
Hi guys, i need ori files, ecu burned. Iveco Daily 3,0l 0281011228 1039S09673 F1CE 0481A 50C14HPI EDC16 c8
thanks in advance.
i have some files , but dtc 0010 and limp mode
My English is little bit bad, but day after day is better. Like my experiences https://www.youtube.com/channel/UCdT...bx2Pc7WI4pWUWA
My help not for free, press THANKS and REP, for make me HAPPY
im not using passwords, my work is for this forum and members free
0281011228 BDM
Pyromaniak (14th February, 2018)
P0010 - Camshaft sensor circuit?
Alientech KESS + KTAG, MagPro2 X17, FLEX Flasher, AVDI by Abrites, WinOLS Genuine Full, Maha LPS3000 Dyno machine.
Pyromaniak (16th February, 2018)
yes, if iveco have same codes like eobd... Camshaft senzor new, voltage to senzor 5v, osciloscope signal controled. Timing chain controled. vires with signal measured by the way to mpc...
I thing have bad data for ecu, or something. Now i try reflow mpc. but nothing, every same.
Please can everyone off limp and this dtc? 0010 - my delphi say unknown code
Check the timing belt for stretched. I had same issue. After replace belt problem solved
Pyromaniak (17th February, 2018)
i have chain, its one year old, maybe 10000-15000 km. Car is in weekend use only... i have looked on timing, i borow special tool for aretation. everything is ok.
Be my guest!
konq100 (16th February, 2018), pike (16th February, 2018), Pyromaniak (16th February, 2018)
hi bobolino, thank you wery much. Stil have same dtc, i have immo off maybe is problem in eeprom? i need working file for 0281011228 ecu motor f1c 3.0 with no egr (car have not from fabric) no variable turbo and immo off if posible.
Thank in advance
edit. now i try with KTS (borowed from friend) and have code $10 and with delphi 0010, but no P0010
if you want to try this solution dtc 0010 off
thank you, i try it and report
Yes, i know, that this is error code #10, there is not OBD codes in this file... and for sure i've delete it.
Unfortunately, ESI don't have description for this code. What the KTS said about this code? Or is unknown?
How did you flash my file? I hope BDM, not OBD...
And second... have you limp mode again?
Regards!
What the KTS said about this code? kts say engine driving (řízení motoru) i think my immo off eeprom is very diferent, its possible my problem?
yes, i write by bdm.
i think limp is on, i not drive, but motor can not go over 3200 rpm on neutral. (its possible this car have launch control like mercedes vito? on place no go over3000.)
thank you
Test this file... about limp...
The pass is same.
