Results 1 to 9 of 9
    Nicolas9's Avatar
    Feb 2017
    Aruba
    Default problem odometer corolla 2006
    hi guys.
    i have a odometer from toyota corolla from 2006. with chip 93c46.
    when read eeprom it reads 141223km. this is correct.
    but on display of odometer in the car it shows 00000km
    anyone knows what the problem is?
    thnx!
    Nov 2016
    Bad soldering i think
    DashProg's Avatar
    Jan 2013
    Here
    what's the km u need? try this dump,
    Everything will be back in order - All my respects to DK's members.
    Nicolas9's Avatar
    Feb 2017
    Aruba
    didnt desolder. so thats not problem.
    i need 141223km. but thats already in file. but as I said. when put cluster in car, then display shows 00000
    DashProg's Avatar
    Jan 2013
    Here
    Quote Originally Posted by Nicolas9 View Post
    Much better desolder then write back the dump that i post
    Cllau's Avatar
    Mar 2017
    where friends need me
    write this dump and see if you get km on display... It's different km value but we will adjust after if it's working....
    Cllau's Avatar
    Mar 2017
    I believe you got this issue from bad Eep. writing....
  8. The Following User Says Thank You to Cllau For This Useful Post:
    Nicolas9 (14th February, 2018)
    Aug 2015
    did u remove eprome from cluster to reprograme
  10. #9
    Nicolas9's Avatar
    Feb 2017
    Aruba
    thnx.
    i'll try the file from dashprog!
