Results 1 to 12 of 12
Thread: Samsung J510FN
    ilen's Avatar
    Feb 2013
    Serbia
    Default Samsung J510FN
    Samsung J510FN will not start, just flashes, samsung on screen. after that i wrote the firmware with Odin3, but the same. can anybody help me...
    Thenxx...
    Послато са SM-J500FN уз помоћ Тапатока
    jodge's Avatar
    Mar 2017
    - Go to reco menu and check the current sw version on the firs (second) row
    - Choose the same or higher unbranded version (J510FNXX......unbranded or J510FNXE... the slavic)
    - Use the 4 file version flash, if you have 5 files (2 kind CSC) use the regular not the HOME_xxxxxx
    - After succesfully flash go to recovery menu and perform hard reset
    If the phone still not starting it means probably 2 thing:
    - The EFS is damaged /erased = you can't do anything w/o proper tools --> samsung service centre or skilled independent service (the main reason is w/o MSL code or other paid service the cable unlock is impossible but some "smart" guy well...."smart" )
    - The phone hw is damaged, mostly the emmc going bad or the built-in RAM it means the authorised service center will change the main pcb for free if the warranty is intact
  3. The Following User Says Thank You to jodge For This Useful Post:
    ilen (16th February, 2018)
    ilen's Avatar
    Feb 2013
    Serbia
    I only have Firmware J510FNXXU2BQJ8 2,8 GB, I put it in PA.
    After succesfully flash go to recovery menu and perform hard reset, but update only 32 % , ... and stop....
    ilen's Avatar
    Feb 2013
    Serbia
    jodge's Avatar
    Mar 2017
    if knox isn't tripped or disassembled drop back to warranty. It seems the emmc is gone.
    ilen's Avatar
    Feb 2013
    Serbia
    I need a BL + AP + CP + CSC file for this J510FN or a link to downland....
    Thenxx...
    jodge's Avatar
    Mar 2017
    It's available only in paid support. You can pay via paypal on many site.
    or send me your current sw version. You can check it on the recovery first-third row.
  9. The Following User Says Thank You to jodge For This Useful Post:
    ilen (21st February, 2018)
  10. #8
    jodge's Avatar
    Mar 2017
    BTW your phone originally from Italy , sold on 2016.05.12 with 1 year warranty
    According the service bulletins your problem could be:
    - Bad lcd (yes even w/o any mark of damage)
    - Qualcomm PMU (power management unit)
    - Emmc (mostly it's flip to write protected mode)
    - And sw related problems
  11. #9
    May 2013
    Manchester
    problenm with EMMC Chip, Either bootloader damaged or Emmc reballing.
  12. #10
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by mobileunlockers View Post
    if the bootloader is damaged there is no download mode at all.
    In this case the cpu core loader couldn't pass the boot chain to the SBL and the qulacomm EDL port is appears (QCHS-9008)
  13. #11
    tray to use Samsung software by sn
  14. #12
    samsung smart switch
