Results 1 to 3 of 3
    UK
    Default LDV Maxis Edc16c39
    Hi all
    I need to remove speed limiter from this ECU. Is it a bdm job only or is it possible to read flash via obd?
    Kess told me to use protocol 134 but the only 134 was in PSA/mitsubishi so I selected that one and on trying to ID i got a generic error. Could not find it in fgtech or MPPS either
    Is it possible to r/w via obd?
    if this post was usefull
    please press
    the thanks button
    mihaiservice's Avatar
    http://www.quick-tuning.com
    project in file are similar to Iveco but not sure if you read can read/write file via OBD like Iveco with EDC16C39 ecu !
    Full WinOLS user
    Custom ENG/GER OLS file for ​ Tune /DPF / SCR / EGR / TVA / VSA / DTC and more...
  3. The Following User Says Thank You to mihaiservice For This Useful Post:
    looly (17th February, 2018)
    Ireland
    Try read OBD Mitsubishi or BDM.
