Results 1 to 2 of 2
    Mar 2015
    Default Astra 1.9 DPF and EGR OFF help
    Hello, please help me in manual solution of DPF and EGR off in Opel Astra 1.9CDTI with EDC16C39 ECU. Solution with DPF Remover not working properly.Here is dump, P2452 error is permanent. Thank you so much.
    May 2017
    Turkey
    Test and report please.
    You can disconnect egr plugin from egr.
    If car have a dtc after disconnect plugin, you can sent me the dtc. I will remove for you.
