Results 1 to 15 of 21
Thread: W202 c220 cdi
Hybrid View
    Default W202 c220 cdi
    Hello.got this w202 with ecu 0281001881 always with error p1622 y75 valve.can someone please remove it completly?
    unnamed11112007's Avatar
    Aug 2015
    Belarus Molodechno
    file for you
    p1622 DTC off
    -------------->mercedes_2 2 dci_p1622 dtc off_chks ok.rar
    good luck
    tell me thanks I will be very happy
  3. The Following 2 Users Say Thank You to unnamed11112007 For This Useful Post:
    Jabeer445 (22nd April, 2019), xpto (18th February, 2018)
    Sorry but dont work.car dont crank
    No one can help?
    johak's Avatar
    try this...
  7. The Following User Says Thank You to johak For This Useful Post:
    xpto (19th February, 2018)
  8. #6
    Gonna try.is checksum corrected?
  9. #7
    johak's Avatar
    yes, corrected
  10. #8
    Dont know way but car still no work
  11. #9
    johak's Avatar
    the problem is in checksum
    probably my winols did not calculate it correctly
    with which tool write file?
  12. #10
    I use willem
  13. #11
    johak's Avatar
    if you have a kess try with it
    you first need to write an original with willem then via obd with Kess
    kess will calculate checksum
  14. #12
    And kess read the complet flash?
  15. #13
    johak's Avatar
    yes it is edc15
    but you will only write file with kess
  16. #14
    No way.with original ecu is still dead.dont know what wapen.gonna tey in other ecu with kess
  17. #15
    Ok.gonna try
