here you go
Hello friends, can a little help for 1 files ,iveko dayli 3.0 model 3015 . So I want to leave the turbo limiter at 2600, because after Stage 1 the bus makes a pressure of 2500 m/b,if you can check I have done with all limiter on the turbo so it does not go into emergency mode.Attach a file with the modified file + original, I would be very grateful if you check everything related to the turbo as it should be, from limiter.The turbo is wastage
Thenks before you big helps
here you go
i thins you not see my files ,i up that limiter and svbl and 1 more ,witch that have emergency mode i test him
Can no one help? for my files , and to check if all the limitors are fixed?
our work on your facebook again?
DSG TUNING
File Service
Ok, i watch my Polish ass my good friend
I just wait when you came to Poland to get some work .
Best regards.
DSG TUNING
File Service
konq100 (20th February, 2018)
