Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Feb 2018
    Default Please help, i ~~~~ed up. Opel Insignia 2.0 EDC17C19
    Hi guys
    I need some help here.
    Flashed a EDC17C19 Insignia ECU and now the car wont start.
    When I open the door or turn of the ignition there is a strange sound coming from the engine bay, sounds like a actuator is moving or something.
    Tool used is a 7.020 ktag clone, it says the write was successful.
    Any ideas what might be causing this?
    norman1967's Avatar
    Dec 2015
    Amsterdam
    What fault codes do you have?
    Genuine tools including Abritus, Autotuner Master, Bosch Ford vcm2, smok UCDS FULL JTAG FULL pcm flash, IO terminal, UPA, Autel maxicom pro, MTX dpf, dtc, immo edc17 UCDS, and a little well maintained hairy box from china I play inside!
    4.94 x100 fgtech kess ktm ktag mpps skp. And still collecting
    Feb 2018
    Quote Originally Posted by norman1967 View Post
    ECU communication error
    Canbus error
    And a bunch more, I will go have look now!
    Feb 2018
    Jun 2013
    Why you flashed ecu? Checksum good?
    Wysłane z mojego SM-G390F przy użyciu Tapatalka
    norman1967's Avatar
    Dec 2015
    Amsterdam
    I have only ever used my 7020 twice. The second time was to write a Mercedes b class it did not ask me to do the chks. The car started once cut out and never started again I have dtc for chks. If i was you I'd wrote back origonal with another tool. Or if you have not another tool try woth your 7020 again wrote origonal
    Feb 2018
    Yeah I tried to write back the original file but the car still behaves the same. And now I cant read or write using Kess anymore
    Feb 2018
    I think I have sourced the problem to my tool or/and software.
    When I write a file and read it again its been messed up in the are between 013FE4 and 017FE4
    Feb 2018
    Quote Originally Posted by wbart View Post
    Its a friends car, he wanted me to flash a chip tuning file.
    Feb 2018
    I have attached the original file, and the original file after I wrote it with ktag and read it again.
    Oct 2017
    dunno why read file has some extra data at the begining...did u check eeprom read too to see if it got corrpted? cause ori looks fine!
    Jun 2012
    You sure no solder left on PCB or bad solder job on Boot pin ??
  13. #13
    Feb 2018
    Quote Originally Posted by autoSP View Post
    I have a eproom read on my computer, will check it tomorrow.
    Everytime I write the ori file and read it again it will come out with a 100% match to that file with extra data in the beginning.
    Quote Originally Posted by pulsar2000 View Post
    No soldering involved, used a needle for the boot pin
  14. #14
    Feb 2018
    I have a kess that i tried in tricore. But it wont ID, read or write the ECU.
    But it says it can do TOTAL read or write.
    So maybe if somebody have a TOTAL read from this ecu I can to write it?
    HW:
    SW: 1037529592
    VIN nr.:
    SW ver.:
    Spare:
    Engine:
    HW Ver.:
    SW upg.: P564_OB8
    Installation:
  15. #15
    norman1967's Avatar
    Dec 2015
    Amsterdam
    Quote Originally Posted by makri View Post
    HW:
    SW: 1037529592
    VIN nr.:
    SW ver.:
    Spare:
    Engine:
    HW Ver.:
    SW upg.: P564_OB8
    Installation:
    If it won't Id another origoanl file will not help mate
    I've never used kess on this ecu.
    Does it id with your ktag?
