So far results are better and better for me, although Autel should still step up on the complaint response (not after 2 weeks asking to test a beta... that car will not be with you at that time, or something is seriously wrong!)
Last 2 days:
Peugeot 207 - pin ok, coding ok, remote had to be added manually (procedure in IM608)
Hyundai Getz 2007 - pin by vin conversion in Autel, added key fine (handy baby 2 did not decode the key correctly and had no chips on me for the Mini Key VVDI and KD-X2 which decoded fine)
VW Caddy 2007 - added key after making dealer key fine (not even reprogram other key) and added remote fine as well - used smart detection menu
Benz CLS350 2005 - calculated pass and added key with smart system within 10 - 15 minutes
in my experience, if you do benz and it asks to turn on and off the key .. prepare for long time in the job (can take easily 30 minutes and boredom as hell for turning on and off ignition sooooo many time)...
also a question - if you do benz, which machine best to make the emergency key. It's no standard fit in my Sec E-9 and the adaptor is stuck in Chinese freight mess up due to the C. virus as it seems. Only have the clamp tools for the manually cutter,
especially if you do older ones, the blade from a non working key won't fit in newer chrome key so you are doomed to make one most of the times
