Page 5 of 10 FirstFirst 12345678910 LastLast
Results 61 to 75 of 136
  1. #61
    Apr 2018
    uh what's that mean?
  2. #62
    Jan 2017
    USA ����
    anything new out there
    The thanks button is HERE looks like this --->>> THANKS
  3. #63
    jodge's Avatar
    Mar 2017
    it seems the face group is active
    Sir, are you classified as human? Negative, I am a meat popsicle
  4. #64
    salkapone's Avatar
    Oct 2013
    anyone know where to finde this IM for good price ??
    Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
  5. #65
    salkapone's Avatar
    Oct 2013
    Quote Originally Posted by K1nd3r View Post
    yes, if you have "VANGA" phone number
    K1nd3r
    VANGA
  6. #66
    Jan 2017
    USA ����
    No Im508 is new im300
    Im608 is new im600
  7. #67
    Jan 2017
    Netherlands
    Got the IM608 and did Ford Mondeo key add (no pin needed) on 2009 edition. FOB activation had no info on this, you need to find that out yourselves (ofcourse you all know it already :P )
  8. #68
    Jan 2017
    Netherlands
    VW Up! 2013 - added key, read pincode, c/s etc nice. Created dealer key and programmed remote. Had to relearn keys again first time, but think it was just on me. Propably me, need to get used to this but we have learn keys, add keys, and make key. Make a dealer key is clear, first to be done (read immo first!) but learn key and add key were not clear to me... just learned them after making the dealer key.
  9. The Following User Says Thank You to Matronix For This Useful Post:
    kostat (28th September, 2019)
  10. #69
    p1et's Avatar
    Oct 2013
    ADD key means just add new key without deleting keys (no need of reprogramming working keys)
    Learn keys means delete keys, put number of needed keys and program old + new one by one.
  11. The Following 2 Users Say Thank You to p1et For This Useful Post:
    kostat (28th September, 2019), Matronix (29th May, 2019)
  12. #70
    Jan 2017
    Netherlands
    Polo 1.4 - 2005 - read pincode fine, did learn key, took a few times (maybe a bad chip?) but eventually had both keys learned and working
    noticed a 'copy megamos 48 ' option but had no luck when trying (just out of curiosity) , will try to copy a 48 when back at basecamp
  13. #71
    Oct 2016
    anybody may confirm new Fiat precoding and adding remotes via obd?
    many thnx.
  14. #72
    Jan 2017
    Netherlands
    @Romir, sorry, not tried as yet
    today tried a Meriva 2005 - Opel -- fail --
    pincode reading correct
    adding key says turn off ignition, but then the pincode is not accepted so think procedure not described correctly in tool
    also no option for activation of remote
    checked code with Abrites, was correct so reading pin is ok, coded key with abrites, activated remote with OpCom Advanced
  15. #73
    Jan 2017
    Netherlands
    Smart 450 - 1999 , the brand is not even in the immo section so no go on this, as expected ... keys are hard to get for the oldest of Smart cars anyway ofcourse (seeing a lot of 'wrong' newer types which I can never get to work on the old Smarts, not even with Xentry)
  16. #74
    p1et's Avatar
    Oct 2013
    I've tested 3 remote button on old Smart 1999/2000 and working good... Programming by MVP Pro
  17. The Following User Says Thank You to p1et For This Useful Post:
    Matronix (17th August, 2019)
  18. #75
    Jan 2017
    Netherlands
    anyone tried Golf 7 / MK7 with IM608?
    Not even sure the support it, no specific Golf 7 in the supported vehicle list?
    Should be able to do with Handy Baby 2 but I don't feel comfortable with that (adding by obd2 and jmd extra tool)
