uh what's that mean?
anything new out there
The thanks button is HERE looks like this --->>> THANKS
it seems the face group is active
Sir, are you classified as human? Negative, I am a meat popsicle
anyone know where to finde this IM for good price ??
Recovery Service ,File Service [COLOR=#00ff00][FONT=system]VAG ,PSA,Renault ,FIat IMMO solutions!!BMW solutions!! Volvo solutions!! Audi BCM2 repair ,key programing .module matching !!MB solutions !!! CAS / FEM / BDC Recovery !! Poldiag Keymaster seller
K1nd3rVANGA
No Im508 is new im300
Im608 is new im600
Got the IM608 and did Ford Mondeo key add (no pin needed) on 2009 edition. FOB activation had no info on this, you need to find that out yourselves (ofcourse you all know it already :P )
VW Up! 2013 - added key, read pincode, c/s etc nice. Created dealer key and programmed remote. Had to relearn keys again first time, but think it was just on me. Propably me, need to get used to this but we have learn keys, add keys, and make key. Make a dealer key is clear, first to be done (read immo first!) but learn key and add key were not clear to me... just learned them after making the dealer key.
kostat (28th September, 2019)
ADD key means just add new key without deleting keys (no need of reprogramming working keys)
Learn keys means delete keys, put number of needed keys and program old + new one by one.
Polo 1.4 - 2005 - read pincode fine, did learn key, took a few times (maybe a bad chip?) but eventually had both keys learned and working
noticed a 'copy megamos 48 ' option but had no luck when trying (just out of curiosity) , will try to copy a 48 when back at basecamp
anybody may confirm new Fiat precoding and adding remotes via obd?
many thnx.
@Romir, sorry, not tried as yet
today tried a Meriva 2005 - Opel -- fail --
pincode reading correct
adding key says turn off ignition, but then the pincode is not accepted so think procedure not described correctly in tool
also no option for activation of remote
checked code with Abrites, was correct so reading pin is ok, coded key with abrites, activated remote with OpCom Advanced
Smart 450 - 1999 , the brand is not even in the immo section so no go on this, as expected ... keys are hard to get for the oldest of Smart cars anyway ofcourse (seeing a lot of 'wrong' newer types which I can never get to work on the old Smarts, not even with Xentry)
I've tested 3 remote button on old Smart 1999/2000 and working good... Programming by MVP Pro
Matronix (17th August, 2019)
anyone tried Golf 7 / MK7 with IM608?
Not even sure the support it, no specific Golf 7 in the supported vehicle list?
Should be able to do with Handy Baby 2 but I don't feel comfortable with that (adding by obd2 and jmd extra tool)
