Results 1 to 5 of 5
    Jun 2012
    Default help with dtc sid 801a
    hi
    I need help with dtc sid 801a
    dtc P1351 P1352 P0124
    I try to do off 11610 and 11A82, but when modifying ecu it stays dead and I have to desolder flash
    dominik.m's Avatar
    Jun 2009
    POLAND
    Are You calc CKS?
    Jun 2012
    yes, calculated.
    something I have modified badly
    johak's Avatar
    try with this file
  5. The Following 2 Users Say Thank You to johak For This Useful Post:
    javiere (21st February, 2018), nabilrifi (21st March, 2018)
    Jun 2012
    Quote Originally Posted by johak View Post
    try with this file
    with your file dtc P0000 active
    is still active limp mode
    i solved the problem by changing ecu.
    I have same dtcs but not limp mode
    I do not get it
