Page 19 of 44 FirstFirst ... 9141516171819202122232429 ... LastLast
Results 271 to 285 of 652
  1. #271
    Dec 2010
    Nottingham
    it is indeed life and just another cross we bare , just another pit fall
  2. #272
    May 2018
    Mazda 6 2008 chip 4d63 add key ok
  3. #273
    lion0304's Avatar
    Oct 2014
    Ford F150 2008 USA, AKL ok, add 2x 4D63
    ASX 2012, clear stolen remote key OK (only by AKL). This car is weird, clear remote OK, but can only add 1 remote
    Tried many tool X100, Xpad2, SKP900, Ikey820 all the same.
  4. #274
    May 2018
    Ford mondeo 2002 tibe key add 1 key ok no need to wait 10 mins.
  5. The Following User Says Thank You to GideaAdrian For This Useful Post:
    p1et (20th August, 2019)
  6. #275
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    what was the new merc and bmw update yesterday ?
  7. #276
    Mar 2018
    UK
    I just found out that if I add key on Astra J and first put the existing key there is no need to wait 10 minutes
    Before I always started with the new key and waited 10 minutes
  8. The Following User Says Thank You to Manta1600 For This Useful Post:
  9. #277
    Oct 2018
    Northern Ireland
    Doing a 2005 Hyundai Tuscan tomorrow does xpad calculate old code for new or do I need to use another tool to do calculation ?
    Thanks 👍🏻
  10. #278
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by Jimmy07 View Post
    Thanks 
    2005 you need only 6 last digit, Xpad2 convert to old pin OK
    I never succes read new pin for Kia Hyundai, even with exiting key.
  11. The Following User Says Thank You to lion0304 For This Useful Post:
    Jimmy07 (22nd August, 2019)
  12. #279
    Oct 2018
    Northern Ireland
    Thanks Lion 👍🏻
  13. The Following User Says Thank You to Jimmy07 For This Useful Post:
    lion0304 (23rd August, 2019)
  14. #280
    Oct 2018
    Nissan Micra MK12 works but need to generate pin code from glovebox so need to find a external calculator.
    Renauly Meganes work for key card
    VW Golf 2004 works
  15. The Following User Says Thank You to bioggy For This Useful Post:
    Manta1600 (23rd August, 2019)
  16. #281
    Oct 2018
    Northern Ireland
    Will xtool 100 pad do 2012 Nissan Note ( standard key not proxy ) ?
    Does it bypass code and will it add key or delete all keys then put back in ?
    Thanks in advance 👍🏻👍🏻
    Jimmy
  17. #282
    Mar 2018
    UK
    Thanks in advance 
    Jimmy
    Will add key but you will need code that is calculated from glovebox number
    If I remember right will delete all existing keys and then will add back
  18. The Following User Says Thank You to Manta1600 For This Useful Post:
    Jimmy07 (2nd September, 2019)
  19. #283
    Oct 2018
    Northern Ireland
    Thanks Manta will order code from broker or post on here 👍🏻
  20. #284
    Mar 2018
    UK
    Ford Fiesta 2010 AKL - Done the job for 20 seconds
  21. #285
    Oct 2018
    Northern Ireland
    2012 Nissan Note pulled wrong pin but went straight in with known pin code in 2 minutes
