Page 20 of 43 FirstFirst ... 10151617181920212223242530 ... LastLast
Results 286 to 300 of 652
Hybrid View
    Dec 2010
    Nottingham
    its common knowledge that nissan have various bad bcm modules affecting qashqai j11 , xtrail t32 and rogue models using the prox key system , if you get one of these affected units then no tool can code new keys to it and will kill car , thus why so many avoid the qashqai j11 , xtrail t32 and rogue models with prox system , advanced diagnostics warn of 2 bad bcm serials not to attempt , truecode warns of 4 bad ones to avoid , even tdb warns of 2 on their wiki info, theres a thread on this forum on another one to avoid . theres also a few that some have succeeded and some have killed car , so these can be a lottery at best of times.
    if an affected bcm then not even the dealer can code keys to car with dealer tool without killing it . this has been common knowledge for sometime now , with many threads over past few years on the matter on many forums and groups including this forum , with prox systems on these models its a lottery , you get lucky or you dont , plenty avoid them .
    nissan are well aware of the issue as an internal bulletin was sent to all dealers warning them , but despite this they still charge 2k plus if a locksmith kills one , despite it being an issue in their bcm .
    its easy to blame a tool , not so easy to blame ones self if the right checks were not made prior to attempting key programming . ad kit and truecode read the bcm serial prior to programming and warn you to walk away if one of the bad serials and have you click to confirm that you understand that if you proceed you do so at your own risk and cost if it goes wrong .
    did you check bcm serial before proceeding to be certain it wasnt an affected unit as if it was an affected bcm then the fault is purely yours for not checking and of course nissans bad bcm units , and not your tools fault , its become far to easy to blame your tools , of course we dont yet know all the bad bcm units , 1 member here had one that was not listed that killed car , so we dont know all the bad ones yet and some are good sometimes and bad other times , thus why many avoid these .
    those that like a gamble take a chance on them , and charge well , some get lucky and get paid , others get unlucky and must pay the stealer , i guess it comes down to do you do enough of these to make the ones you kill and the cost to fix worthwhile , if you do great , if not then leave them alone , we all like to blame someone but if an affected unit then blame yourself for not researching and checking or blame nissan and their known bad bcm units , but dont blame your tools because their an easy target as you would suffer same fate with dealer tool if an affected unit. but in some cases its just bad luck as a bcm serial that isnt known to be bad yet but again not the tools fault.
    warn your customer of the issues , advise dealer , if they want you to proceed then get something in writting that you have made them aware of the risks and issues and they want you to try and they take full responsibility if shit hits fan , its not cast iron in court but may help , failing that learn which serials are bad , always check before proceeding and avoid models with affected bcm serial numbers or take the gamble knowing its on you if it goes bad..
  2. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    godfathertre (16th August, 2019)
  3. #2
    Dec 2016
    Quote Originally Posted by rapidlocksmiths View Post
    if an affected bcm then not even the dealer can code keys to car with dealer tool without killing it . this has been common knowledge for sometime now , with many threads on the matter on many forums and groups including this forum , with prox systems on these models its a lottery , you get lucky or you dont , plenty avoid them .
    Yes it's life
    Dec 2010
    Nottingham
    it is indeed life and just another cross we bare , just another pit fall
    May 2018
    Mazda 6 2008 chip 4d63 add key ok
    lion0304's Avatar
    Oct 2014
    Ford F150 2008 USA, AKL ok, add 2x 4D63
    ASX 2012, clear stolen remote key OK (only by AKL). This car is weird, clear remote OK, but can only add 1 remote
    Tried many tool X100, Xpad2, SKP900, Ikey820 all the same.
    May 2018
    Ford mondeo 2002 tibe key add 1 key ok no need to wait 10 mins.
  8. The Following User Says Thank You to GideaAdrian For This Useful Post:
    p1et (20th August, 2019)
  9. #7
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    what was the new merc and bmw update yesterday ?
  10. #8
    Mar 2018
    UK
    I just found out that if I add key on Astra J and first put the existing key there is no need to wait 10 minutes
    Before I always started with the new key and waited 10 minutes
  11. The Following User Says Thank You to Manta1600 For This Useful Post:
  12. #9
    Mar 2008
    birmingham
    Quote Originally Posted by Manta1600 View Post
    will try this , have one next week
  13. #10
    Oct 2018
    Northern Ireland
    Doing a 2005 Hyundai Tuscan tomorrow does xpad calculate old code for new or do I need to use another tool to do calculation ?
    Thanks 👍🏻
  14. #11
    lion0304's Avatar
    Oct 2014
    Quote Originally Posted by Jimmy07 View Post
    Thanks 
    2005 you need only 6 last digit, Xpad2 convert to old pin OK
    I never succes read new pin for Kia Hyundai, even with exiting key.
  15. The Following User Says Thank You to lion0304 For This Useful Post:
    Jimmy07 (22nd August, 2019)
  16. #12
    Oct 2018
    Northern Ireland
    Thanks Lion 👍🏻
  17. The Following User Says Thank You to Jimmy07 For This Useful Post:
    lion0304 (23rd August, 2019)
  18. #13
    Oct 2018
    Nissan Micra MK12 works but need to generate pin code from glovebox so need to find a external calculator.
    Renauly Meganes work for key card
    VW Golf 2004 works
  19. The Following User Says Thank You to bioggy For This Useful Post:
    Manta1600 (23rd August, 2019)
  20. #14
    Oct 2018
    Northern Ireland
    Will xtool 100 pad do 2012 Nissan Note ( standard key not proxy ) ?
    Does it bypass code and will it add key or delete all keys then put back in ?
    Thanks in advance 👍🏻👍🏻
    Jimmy
  21. #15
    Mar 2018
    UK
    Thanks in advance 
    Jimmy
    Will add key but you will need code that is calculated from glovebox number
    If I remember right will delete all existing keys and then will add back
  22. The Following User Says Thank You to Manta1600 For This Useful Post:
    Jimmy07 (2nd September, 2019)
