Page 25 of 43 FirstFirst ... 15202122232425262728293035 ... LastLast
Results 361 to 375 of 652
Hybrid View
    Oct 2018
    Northern Ireland
    I thought I had full version ?
    EU updates for key programming are few lately. Other tools are way ahead like OBDSTAR DP pad
    Dec 2016
    Quote Originally Posted by Jimmy07 View Post
    it's full Aliexpress 800$ version !
    Another version available in France ,India ,Brazil .... But price is 1800$ like OBDSTAR DP pad & Lonsdor
    Oct 2018
    Northern Ireland
    Gotcha so France got offered full version rest of us got offered the scraps 😬
    Dec 2016
    Gotcha so France got offered full version rest of us got offered the scraps 
    French & Brazilian version Can programming Megane 3 Dacia 2012+ keys & Cards since 2 years ago , before ObdStar & Lonsdor ...
    Oct 2018
    Northern Ireland
    AKL Micra job
    Will this pull code for 2005 Nissan Micra ( 2 button non proxy square key ) ?
    lion0304's Avatar
    Oct 2014
    AKL Micra job
    Micra K12, you need just 12 digits from glove box sticker and convert by XPad2 for pin
    Key need 2 buttons with PCF7946
  7. The Following User Says Thank You to lion0304 For This Useful Post:
    Jimmy07 (18th October, 2019)
    Oct 2018
    Northern Ireland
    Thanks Lion didn’t see 12 digit calculator option on xtool only seen 6 digit option will have another look
    May 2019
    With xtool x100 pad2 pro working next:
    1.VW golf 4 2004 read pin code and add key -OK
    2.Vw polo 9N 2002 read pin code and add key-OK
    3.Citroen c2 ,c3 c4 2002-2010 read pin code and add key-OK
    4.Skoda Fabia 2013-read pin code and add key-OK
    5.Citroen c4 picaso 2013-OK
    6.Peugeot 407 2006 add key-OK (Thank you Terminator 1000)
    7.Peugeot 307 2008 read pin code and add key-OK
    8.VW passat 2001 read pin code and add key-OK
    9.Chervolvet aveo 2009-add key -OK
    10.Renault Megan 2005 read pin code and add key- OK
    11.GOlf 4 2002 Read pin code-NOT GOOD
    12.Golf 5 2007 read pin code OK ,but i cant to add key
    13.VW POLO 9n3 dashboard 6q0920804 and ECU Siemens VDO Petrol SIMOS 9.1 I TRIED TO READ PIN CODE AND FAIL (ALL WORKING KEY IS LOST ).I CANT BELIEVE IT. (I TRIED AND VAGTACHO 3.0 ,VAGTACHO 5.0 ,FVDI 2018 AND I CANT READ PIN CODE ) ANY COMMENT OF THAT . n9 dVW on't like that renault can't insert pin code manually but it is automatic.
    I tried to read pincode on FIat Bravo 2009 year .NOT GOOD .And if you have this problem just reset bsi and key is working .Do not tried to read pin code on fiat .....
  10. The Following User Says Thank You to jvladaaa For This Useful Post:
    Manta1600 (19th October, 2019)
  11. #9
    Ashraf6119's Avatar
    UK
    Tried today to do millage on WV Touran 2010 it did read the type of instrument as CDC32XXX but, could not do the millage, tried other few options non of them could work it also could not save the eeprom data file......
    Has any one of you been able to do millage one this model............?
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  12. #10
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    title of the thread needs changing too whats not workin
  13. #11
    Oct 2018
    Northern Ireland
    Is there any UK-EU immo updates due soon ?
  14. #12
    Ashraf6119's Avatar
    UK
    There were some updates today but, most of them were for diagnostic the only immobiliser update was for Honda only
    Thanks Ash
  15. The Following User Says Thank You to Ashraf6119 For This Useful Post:
    Jimmy07 (19th October, 2019)
  16. #13
    May 2018
    when programing remote for vag group under k-line you need to erase all remotes then you can program new remotes if you don`t erase them all you will get failed to conect
  17. #14
    Oct 2018
    Northern Ireland
    2010 VW Tiguan remote programmed ok
    Other tools failed on this ( damaged repaired vehicle )
  18. #15
    Mar 2008
    birmingham
    LATER shape key or old shape ?
    its ok its was a touareg l was having problems with
