Results 1 to 15 of 652
Hybrid View
    May 2019
    With xtool x100 pad2 pro working next:
    1.VW golf 4 2004 read pin code and add key -OK
    2.Vw polo 9N 2002 read pin code and add key-OK
    3.Citroen c2 ,c3 c4 2002-2010 read pin code and add key-OK
    4.Skoda Fabia 2013-read pin code and add key-OK
    5.Citroen c4 picaso 2013-OK
    6.Peugeot 407 2006 read pin code and add key-OK
    7.Peugeot 307 2008 read pin code and add key-OK
    8.VW passat 2001 read pin code and add key-OK
    9.Chervolvet aveo 2009-add key -OK
    10.Renault Megan 2005 read pin code and add key- OK
    11.GOlf 4 2002 Read pin code-NOT GOOD
    12.Golf 5 2007 read pin code OK ,but i cant to add key
    13. I don't like that renault can't insert pin code manually but it is automatic.
    I tried to read pincode on FIat Bravo 2009 year .NOT GOOD .And if you have this problem just reset bsi and key is working .Do not tried to read pin code on fiat .....
    Dec 2016
    Quote Originally Posted by jvladaaa View Post
    407 no communication with Siemens BSI , you are the only user to retrieve an PIN code on this model ?
    May 2019
    You are right about that model peugeot 407 2006 I had the pin code. I just added the keysYou are right about that model I had the pin code. I just added the keys
    May 2019
    6.Peugeot 407 2006 add key-OK (Thank you Terminator 1000)
