Page 25 of 44 FirstFirst ... 15202122232425262728293035 ... LastLast
Results 361 to 375 of 652
  1. #361
    May 2019
    With xtool x100 pad2 pro working next:
    1.VW golf 4 2004 read pin code and add key -OK
    2.Vw polo 9N 2002 read pin code and add key-OK
    3.Citroen c2 ,c3 c4 2002-2010 read pin code and add key-OK
    4.Skoda Fabia 2013-read pin code and add key-OK
    5.Citroen c4 picaso 2013-OK
    6.Peugeot 407 2006 add key-OK (Thank you Terminator 1000)
    7.Peugeot 307 2008 read pin code and add key-OK
    8.VW passat 2001 read pin code and add key-OK
    9.Chervolvet aveo 2009-add key -OK
    10.Renault Megan 2005 read pin code and add key- OK
    11.GOlf 4 2002 Read pin code-NOT GOOD
    12.Golf 5 2007 read pin code OK ,but i cant to add key
    13.VW POLO 9n3 dashboard 6q0920804 and ECU Siemens VDO Petrol SIMOS 9.1 I TRIED TO READ PIN CODE AND FAIL (ALL WORKING KEY IS LOST ).I CANT BELIEVE IT. (I TRIED AND VAGTACHO 3.0 ,VAGTACHO 5.0 ,FVDI 2018 AND I CANT READ PIN CODE ) ANY COMMENT OF THAT . n9 dVW on't like that renault can't insert pin code manually but it is automatic.
    I tried to read pincode on FIat Bravo 2009 year .NOT GOOD .And if you have this problem just reset bsi and key is working .Do not tried to read pin code on fiat .....
  2. The Following User Says Thank You to jvladaaa For This Useful Post:
    Manta1600 (19th October, 2019)
  3. #362
    Ashraf6119's Avatar
    Nov 2009
    UK
    Tried today to do millage on WV Touran 2010 it did read the type of instrument as CDC32XXX but, could not do the millage, tried other few options non of them could work it also could not save the eeprom data file......
    Has any one of you been able to do millage one this model............?
    Thanks Ash
    Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
  4. #363
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    title of the thread needs changing too whats not workin
  5. #364
    Oct 2018
    Northern Ireland
    Is there any UK-EU immo updates due soon ?
  6. #365
    Ashraf6119's Avatar
    Nov 2009
    UK
    There were some updates today but, most of them were for diagnostic the only immobiliser update was for Honda only
    Thanks Ash
  7. The Following User Says Thank You to Ashraf6119 For This Useful Post:
    Jimmy07 (19th October, 2019)
  8. #366
    May 2018
    when programing remote for vag group under k-line you need to erase all remotes then you can program new remotes if you don`t erase them all you will get failed to conect
  9. #367
    Oct 2018
    Northern Ireland
    2010 VW Tiguan remote programmed ok
    Other tools failed on this ( damaged repaired vehicle )
  10. #368
    Mar 2008
    birmingham
    LATER shape key or old shape ?
    its ok its was a touareg l was having problems with
  11. #369
    Oct 2018
    Northern Ireland
    Older keys Smirnoff pre MQB
  12. #370
    May 2019
    14.Opel Corsa C 2004 - ENGINE Z13DT CANT READ PIN CODE ,CANT ADD REMOTE ,JOB FINISH WITH FVDI 2018 READ PIN CODE WITH FVDI AND ADD KEY-REMOTE CAN DO WITH FVDI I USED OPCOM TO ADD REMOTE .
    15.FIat Stuco 2007 cant read pin code ,Cant add key problem like Fiat bravo
    16.I tried to read pincode on FIat Bravo 2009 year .NOT GOOD .And if you have this problem just reset bsi and key is working .Do not tried to read pin code on fiat ....
    17.Peugeot 308 2010 zear add key ,remote OK.Pin code i allready new .
    18.
    I need god key programer for Fiat and Opel .That key programmer must to next .Read pin code ,and add key normal ..Thank you
  13. The Following User Says Thank You to jvladaaa For This Useful Post:
    Ashraf6119 (7th November, 2019)
  14. #371
    Mar 2018
    UK
    Quote Originally Posted by jvladaaa View Post
    Truecode is good for Opel and Fiat but not for all
  15. #372
    Dec 2010
    Nottingham
    abrites is excellent on vauxhall and fiat , zedfull is very good on these too , smart pro good also and truecode is ok too .
  16. #373
    May 2019
    Can you tell me where I can buy true code, consider pro, zed full?
    Do you mean abrites avdi since i have fvdi? THANK YOU
  17. #374
    May 2019
    18.Citroen C3 2007 Add key 2 min job .Pin code allready new .
    19.
  18. #375
    Dec 2010
    Nottingham
    abrites avdi does most fiat by obd , key and remote , you cannot compare fvdi to avdi on fiat as theres a world of difference in coverage , fvdi is a very old copy of old software .
    truecode you can by direct from key programmers or one of their distributors plenty of the uk distributors stock it .
  19. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    smirnoff_rules (8th November, 2019)
