I think it's time now to go for Autel IM608......
Thanks Ash
Oh yes if my post was helpful than Please don't forget to press the Magic word Thanks
Thanks Ash
Program key with clio 2 not working
After my last update no function to add key with PSA and Renault, but I tried to reprogram old card and program new card, with megan 2, all card working !
Not all updates are necessarily good !!!
VW Golf 2006 Diesel 1.9 could not read pin code from engine ECU tried reading using GTi option it did read pin code but did not work looks like it did read wrong pin code.......
Also, ECU Synchronization (matching option) did not work....
Thanks Ash
Peugeot 206 2005, PIN code read -fail
Key added - ok, pin code from other tool
Sent from my Commodore 64
TWINGO 3 * SMART 453 added in SMART menu , no tested yet ( no car to destroy available )
bocaje (1st June, 2020)
Does it do 451 smart ?
yes , in 5 secondes AKL or not , 451 it's an easy car !!!
453 it's another stories , 2 methods is available :
- read flash 30 minutes program blank key = very risky job = need working key https://www.youtube.com/watch?v=CEqHIb5Ok7Q
- made dealer key in one minute AKL https://www.youtube.com/watch?v=3KKJXwphlA0
If x100pad 2 use the first , good luck for future users
Jimmy07 (2nd June, 2020)
no friend , it's reality , tool is for illustration !
Renault cars have bug , after virginize the HFM & BCM , ISK can be read in few seconds , no Seed-Key security ... just calculate ISK to PIN
and learn HFM or BCM with dealer key ( same than used key process )
For Megane 4 / Talisman / Espace 5: PIN in Flash & made dealer key
For old AES : virginize & read PIN & made dealer key
For ME x100pad2 pro NEXT update will be Renault cars , or tool died !
igorr (3rd June, 2020)
