Brof (7th June, 2019)
2009 Mazda 2 ( AKL )
Went to add key option added 4D-63 key 15 seconds
Any feedback on BMW or Fiat with xpad ?
Fiat stilo 2006...original key not rerecognized.try with x100 only when I press read code,x100 "reset dashbord" and key original (customer have one key) start working in key is id48.... tryed again read code same reset dashboard only no read code...but key start working... every fiat i have i can't read code magneti mareli or delphi bsi no luck..
On fiat stilo year forgot maybe 2003 with customer code recode key and remote work fine (customer came for remote not working) that's all for now...
Nissan X trail 2016 added key okay!
Sent from my MI MAX 3 using Tapatalk
Thought this might have pre-coded and programmed Fiat online like 500 model ?
Very little info on this and BMW CAS by OBD
I’ll get to local auction and test soon
Today i have passat 2013,b7 with akl...no luck...( of course)
Audi Q7 2008 mileage correction - OK
done the job under menu 2009-2011 - waiting time around 20 minutes, must be patient
under menu 2006-2008 doesnt work
X100 pad
Audi Q7 2008 add key -ok
Manta1600 (10th June, 2019)
Hello friends is that anyone knows how to reprogram a Mégane III card with XTool x100 pad2 pro?
I did the last update of XTool but I still do not find Megane 3
VW Polo 6R 2011 - black dash - mileage correction - OK
*from second attempt
Before I could do throttle reset for Nissan, now ask for vin# and I do most Japanese model, only frame number, so this function is useless now, is there any way to remove update and use older versions
Hi all , anyone know how to contact xtool support.
2012 spare key wouldn’t program under Opel Vivario or any system 1-8. Programmed under Renault Traffic 2 keys 2 minutes
