sleepyrz (14th January, 2019)
X300 Pro3
FORD C-MAX Hybrid 2013 , add spare key - FAIL
FORD Mustang 2012 all key lost - OK
MAZDA 6 all key lost - Ok
THE JANUARY UPDATE
IMMO
BMW
1. Increased the security mechanisms
2. Increased the SWFL version with key programming
3. Solved the security verification failure in part of models
4. Solved the problem of car start failure with remote key after successful key programming in part of models
VW/AUDI/SKODA/SEAT
1. Increased NEC24C64 MQB key programming
2. Solved Magotan 46 chip generate key failure
3. Solved the flashback problem in automatic recognition of NEC24C32 dashboard
Chrysler
Optimized 2016- Grand Cherokee pincode reading function
GM
1. Increased Cadillac 2017-CT6 smart key system
2. Increased Cadillac 2017-XT4 smart key system
3. Increased Chevrolet 2017- Corvette smart key system
Mazda
1. Increased 2018 CX4 smart key system
2. Increased 2018 Atenza smart key system
Ford
Increased Transit 2014- remote programming
Renault
1. Optimized 08- Megane key programming function
2. Optimized 07-11 Laguna key programming function
Cluster Calibration
GM
1. Increased Cadillac 2017- CT6 cluster calibration
2. Increased Cadillac 2017- XT4 cluster calibration
3. Increased Chevrolet 2017- Corvette cluster calibration
FORD
1. Optimized the low speed problem in Edge EEPROM reading and writing
2. Optimized the low speed problem in KUGA 2012- EEPROM reading and writing
3. Optimized the low speed problem in New Mondeo EEPROM reading and writing
Chrysler
1. Optimized the menu
2. Optimized Compass 2018 cluster calibration (enter system 10 60 mode and then enter its 10 03 extend mode)
ECU Programming
BMW
Solved the security verification failure in part of models.
OBDSTAR X300 PRO3 Key Master .
3 months ago I bought x300pro3.
Why no updates?
If the device is not updated, it makes no sense to buy it!!!
Are you sure, no update(s) in the last 3 month ago ?
Did you try official Obdstar upgrade tool ?
I"m thinking to buy an one year update, but... if no updates...
Polak, wegier dwa bratanki i do szabli i do szklanki
i have gotten updates all the time
all the updates you see above and all the last pages^^^^^^^^^^
but im on a keymaster DP pad full
last 2 bmw updates took forever
large files.......
Obdstar, xc60 add semi smart key problem.
Xc60, 2016, i start the procedure, takes 0 to 8 hours.
After about 4 hours, pin search bar is over 1/3.
Came back the next morning, about 10hours later .
To find that the obdstar has shut down.
Obdstar battery charged 100%.
What happend?, Do i need to check more frequent?
What devise You use And version sW ?
X300dp full, (not the plus), with latest update.
Did You try lost key And try old version from device send log from tool
rob h (30th January, 2019)
I am trying to add a Volvo key.
Again, after about 7 hours, the tablet turns of.
I have send the logs, by email.
To copy anything from device to a usb, i needed to insert a formated usb stick.
The option in the menu to send logs, is no longer there.
