Page 4 of 42 FirstFirst 12345678914 ... LastLast
Results 46 to 60 of 628
  1. #46
    Ford Fiesta 2006 failed to program
    mvp programming no problem
  2. #47
    Apr 2018
    What did the device display when failed?
  3. #48
    rob h's Avatar
    May 2011
    x300dp.
    Continental BSI Q0X 308 T9 2014.
    Read pin, eeprom and flash OK.
    Writing bsi mileage OK.
    Sadly failed to write back the org eeprom, or any other eeprom, from files.
    It does write the eeprom, during mileage adjustement.
    Why is this?
  4. #49
    Apr 2018
    Quote Originally Posted by rob h View Post
    x300dp.
    Why is this?
    Pls attach your log file here.
  5. #50
    Jan 2017
    USA ����
    this is all USA cars
    AKL= all keys lost
    2008 ford expedition AKL try to program keys under every protocol on the machine in ford and nothing worked so i went over to lincoln and used lincoln navigator 07-08 and had to erase all keys and program back in two keys SUCCESS sort of
    2016 ford focus add key incorrect password try to erase keys and got incorrect password again
    had to go to asia region ford focus type 2 it pulled some 4 digit pin code and programmed the keys in about 4-5 minutes SUCCESS
    2016 ford f150 failed on everything apparently x300 can only do up to 2015 f150..... FAIL
    2005 ford five hundred AKL bypass security and erase keys and add back in two new in about 30 seconds SUCCESS
    2015 ford mustang smart key add in spare programmed in about 4-5 minutes SUCCESS
    2015 dodge ram pod add in pin provided by dealer programmed POD y170 under (13- ram) SUCCESS
    2015 chrysler town and country pulled pin and programmed a fobik under (no tooth rotation) SUCCESS x2
    2006 chrysler town and country (pacifica system) pin provided by dealer program success SUCCESS
    2018 toyota 4runner AKL g chip reset and programmed in about 10 seconds SUCCESS
    2016 toyota corolla AKL H chip reset and programmed in about 10 seconds SUCCESS
    2015 toyota camry AKL H chip reset and programmed in about 10 seconds SUCCESS
    2015 mazda cx-5 smart key add in spare success had to try another protocol and it worked SUCCESS
    2015 mazda cx-9 smart key add in spare success had to try another protocol and it worked same as above SUCCESS
    2008 chevrolet impala 12 minute wait and program fine SUCCESS
    2015 infiniti q40 (49622 remote) 4 digit pin x300 can pull the pin and unlock the steering but cannot program in the new key for some reason FAIL
    job completed by skp900 or ck200(ck200 is better at it tho )
    2010 nissan altima (49622 remote) 4 digit pin x300 can pull the pin and unlock the steering but cannot program in the new key for some reason FAIL
    2012 nissan maxima (49622 remote) 4 digit pin x300 can pull the pin and unlock the steering but cannot program in the new key for some reason FAIL
    2013 nissan altima 20 digit bypassed and key programmed in 30 seconds SUCCESS
  6. The Following 5 Users Say Thank You to sleepyrz For This Useful Post:
    Krittanu (4th July, 2018), kronk92 (10th May, 2018), rob h (23rd April, 2018), Siham (26th April, 2018), Tariel (28th April, 2018)
  7. #51
    ray-ray's Avatar
    Have they release the Volvo onto that unit yet & have you tryied it?
  8. #52
    Jan 2017
    USA ����
    im having a bit of an issue there actually ray
    i talked to the obdstar rep on skype for about a year now and i asked her where to get the latest tablet with FULL version she said i have a local distributor (UHS)
    i said ok so i called them and asked if they had the FULL version of the DP tablet and they said they did (2 or 3 different people said this)
    i went on their website and indeed it was listed as full version
    they had a sale and i bought one
    come to find out it is not a full version it is indeed the standard version
    i am currently waiting for a response to what they are going to do
    so in answer to your question ray i cant get the volvo software because i dont have the full version............
  9. #53
    rob h's Avatar
    May 2011
    Yes, Volvo immo is now added.
    It is on my X300DP full since last week.
    Will look for a customer, to try this function!
  10. #54
    Apr 2018
    Quote Originally Posted by sleepyrz View Post
    full version price for standard product? The online seller should be fully responsible
  11. #55
    Apr 2018
    AKL= all keys lost
    2016 ford f150, smart key supported
    Pls attach the log file of failed vehicles.
  12. #56
    Jan 2017
    USA ����
    How do I find log file?
    Also 2016 Ford was flip key I believe
    2009 Dodge Challenger under North America Challenger read PIN code FAIL
    Had to go under type: no tooth rotation type 2
    and pulled PIN code and programmed fobik in 60 seconds
  13. #57
    Jan 2017
    USA ����
    log file how to send
  14. #58
    Jan 2017
    USA ����
    2011 toyota prius smart key
    communicates under type 1 but when i go to immo reset
    says reset not supported FAIL
    job done by ck200 in 16 min
  15. #59
    Jan 2017
    USA ����
    2008 Chevy Malibu AKL
    Popped out ignition in 2 minutes
    Spent the next 15 minutes trying everything in the menu and it wouldn't connect FAIL
    Job done by ck200 in 12 minutes
    2009 Chevy Malibu AKL
    Remembered last fail and just got ck200 FAIL
  16. #60
    Jan 2017
    USA ����
    Ok here's the info on how to send obdstar the log files
    PDF attached
    Finally got all the Chinese and europe only stuff off my menu also by digging into file explorer and just deleting folders I don't want to show
    Also she said if you could edit the log file by FIRST clicking on the log file and THEN with the pencil try to explain how it failed or what went wrong it will make it a lot easier to fix
    Just type it in under "testers notes"
