Page 20 of 42 FirstFirst ... 10151617181920212223242530 ... LastLast
Results 286 to 300 of 628
  1. #286
    Jun 2012
    I tried 3 times,3 transponder locked and not precode ok,no chance to unlock.
  2. #287
    Apr 2018
    Quote Originally Posted by Oras View Post
    I know that support but not working,tested...read ok,save ok,immo data show ok,precode transponder ok,when programming says transponder not precode,locked and kils transponder,no more unlocking 48.
    Pls try this:
    enter into precoding--choose ECU type--unlock the key--generate dealer key again--do key learning
  3. The Following User Says Thank You to SMP7 For This Useful Post:
    sleepyrz (14th January, 2019)
  4. #288
    Apr 2011
    Tbilisi
    X300 Pro3
    FORD C-MAX Hybrid 2013 , add spare key - FAIL
    FORD Mustang 2012 all key lost - OK
    MAZDA 6 all key lost - Ok
  5. The Following 2 Users Say Thank You to Tariel For This Useful Post:
    lalaina74 (15th January, 2019), vsanyi (14th January, 2019)
  6. #289
    Apr 2018
    Quote Originally Posted by Tariel View Post
    X300 Pro3
    Ford C-MAX, what did the device display and do you have log file?
  7. #290
    Apr 2011
    Tbilisi
    Quote Originally Posted by SMP7 View Post
    Maybe " security verification filed " . I do not have a log file.
  8. #291
    Jan 2017
    USA ����
    THE JANUARY UPDATE
    IMMO
    BMW
    1. Increased the security mechanisms
    2. Increased the SWFL version with key programming
    3. Solved the security verification failure in part of models
    4. Solved the problem of car start failure with remote key after successful key programming in part of models
    VW/AUDI/SKODA/SEAT
    1. Increased NEC24C64 MQB key programming
    2. Solved Magotan 46 chip generate key failure
    3. Solved the flashback problem in automatic recognition of NEC24C32 dashboard
    Chrysler
    Optimized 2016- Grand Cherokee pincode reading function
    GM
    1. Increased Cadillac 2017-CT6 smart key system
    2. Increased Cadillac 2017-XT4 smart key system
    3. Increased Chevrolet 2017- Corvette smart key system
    Mazda
    1. Increased 2018 CX4 smart key system
    2. Increased 2018 Atenza smart key system
    Ford
    Increased Transit 2014- remote programming
    Renault
    1. Optimized 08- Megane key programming function
    2. Optimized 07-11 Laguna key programming function
    Cluster Calibration
    GM
    1. Increased Cadillac 2017- CT6 cluster calibration
    2. Increased Cadillac 2017- XT4 cluster calibration
    3. Increased Chevrolet 2017- Corvette cluster calibration
    FORD
    1. Optimized the low speed problem in Edge EEPROM reading and writing
    2. Optimized the low speed problem in KUGA 2012- EEPROM reading and writing
    3. Optimized the low speed problem in New Mondeo EEPROM reading and writing
    Chrysler
    1. Optimized the menu
    2. Optimized Compass 2018 cluster calibration (enter system 10 60 mode and then enter its 10 03 extend mode)
    ECU Programming
    BMW
    Solved the security verification failure in part of models.
    The thanks button is HERE looks like this --->>> THANKS
  9. #292
    Sep 2016
    OBDSTAR X300 PRO3 Key Master .
    3 months ago I bought x300pro3.
    Why no updates?
    If the device is not updated, it makes no sense to buy it!!!
  10. #293
    szkeptmen's Avatar
    Jan 2010
    Hungary
    Are you sure, no update(s) in the last 3 month ago ?
    Did you try official Obdstar upgrade tool ?
    I"m thinking to buy an one year update, but... if no updates...
    Polak, wegier dwa bratanki i do szabli i do szklanki
  11. #294
    Sep 2016
    Quote Originally Posted by szkeptmen View Post
    Yes.
    There were 2 updates for Chinese cars
  12. #295
    Jan 2017
    USA ����
    i have gotten updates all the time
    all the updates you see above and all the last pages^^^^^^^^^^
    but im on a keymaster DP pad full
    last 2 bmw updates took forever
    large files.......
  13. #296
    rob h's Avatar
    May 2011
    Obdstar, xc60 add semi smart key problem.
    Xc60, 2016, i start the procedure, takes 0 to 8 hours.
    After about 4 hours, pin search bar is over 1/3.
    Came back the next morning, about 10hours later .
    To find that the obdstar has shut down.
    Obdstar battery charged 100%.
    What happend?, Do i need to check more frequent?
  14. #297
    Aug 2009
    What devise You use And version sW ?
  15. #298
    rob h's Avatar
    May 2011
    X300dp full, (not the plus), with latest update.
  16. #299
    Aug 2009
    Did You try lost key And try old version from device send log from tool
  17. The Following User Says Thank You to motorsport For This Useful Post:
    rob h (30th January, 2019)
  18. #300
    rob h's Avatar
    May 2011
    I am trying to add a Volvo key.
    Again, after about 7 hours, the tablet turns of.
    I have send the logs, by email.
    To copy anything from device to a usb, i needed to insert a formated usb stick.
    The option in the menu to send logs, is no longer there.
