Results 1 to 12 of 12
    Default Nec D70F3426GJ from VW Jetta
    Hello, I have a faulty dash with this processor from VW Jetta 5C6920970A after unsuccessful VCP flashing.
    I try to read it from the smok jtag,but without success. How to correctly read this processor. I'm adding a photo of the Motherboard
    yugo45's Avatar
    There is no way to read that NEC,it is locked with security bytes.
    It's hard, I was hoping
    Wysłane z mojego SM-J730F przy użyciu Tapatalka
    need help
    Hello, I have a track that his brulet I want a photo of this map to connect the tracks
    thank you
    I send you tonight.
    Jul 2015
    My Car
    are you tested with orange 5 ?
    I solved the problem
    thank you
    Maartinj's Avatar
    Nov 2010
    I can fix almost all 3426 NEC VAG cluster and MFA .....dead , corrupted flash, erased CPU , missing eeprom etc ...
  9. The Following User Says Thank You to Maartinj For This Useful Post:
    polete (18th October, 2020)
  10. #9
    Oct 2014
    Netherlands
    I can do that also. But don't forget restoring immo might be more difficult...
  11. #10
    Maartinj's Avatar
    Nov 2010
    Quote Originally Posted by H2Deetoo View Post
    well.. if data lost / epp lost / cpu delete etc... .... make it virgin is not bad
  12. #11
    Oct 2014
    Netherlands
    Correct! Then match with odis online!
  13. #12
    espa?a
    Hello
    as it does?
    I do not care to delete the complete nec, I just want to recover it because I made a mass and I think the flash of the nec was deleted
