Results 1 to 13 of 13
    Default Zafira edc16c39 enaugh read by OBD for DPF OFF?
    Hi ALl!
    It's enaugh read by OBD for DPF OFF???
    Zafira B 1.9 120HP, EDC16C39, 1037394069
    I ask because the beginning of the file is FF FF.
    I have a solution dpf off but I haven't a car and just why I ask.
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    Enough! Problems can be with dtc! But you can find full bdm file for your soft to do mod and write it by obd.
    REMOVE ALL DTC-EGR-DPF-FAP-FLAPS-CHIPTUNING-IMMO-CRASH
    CLONE ALL VAG ECU !!! REPAIR DUMP ELV,EZS COMFORT AND ECT..
    REPAIR DUMP STEERING ANGLE SENSOR !!! REPAIR DUMP BCM2 !!! KEY PROGRAMMING !!!
    maajkii's Avatar
    Mar 2017
    Poland - Sława ( Lubuskie )
    Bodzio czytaj po BDM, możesz podesłać.
    Wysłane z iPhone za pomocą Tapatalk
    DSG TUNING
    File Service
    AVDigitale's Avatar
    Apr 2017
    Best Place in the World!
    BDM read full map and you can make everything!DPF full removed
    Proffesional ECU & TCU Tuning
    Petrol and Diesel Engines
    File Service
    Apr 2016
    In this case it is...
    Here is a bdm readout of that ecu..
    BR.
    Michael
    Mar 2016
    Sweden
    Is it possible to write full on obd
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    Quote Originally Posted by sonic 1989 View Post
    Possible 1000%
    Mar 2016
    Sweden
    which instrument write full file
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    Example fgtech but you must calculate cs (if you do some modifications ) before writing galletto calculate cs only part of file( that area what can read by obd ) not full file !
    boomeer's Avatar
    Aug 2010
    BELARUS-GRODNO
    In last week have same Zafira b for dpf EGR I read it by obd make all off but when write dtc was on , I have bdm file for same soft (I see where is problem dtc switch class is 6 times in file) I do modifications in bdm file calculate cs and write mod .
    SpecZ Your dump seems like my.
    If your is by BDM I can write my by OBD
    Mar 2016
    Sweden
    Quote Originally Posted by bodzio012 View Post
    this file is not full
  13. #13
    Mar 2016
    Sweden
    Default opel dpf off
    your file full dpf off write via obd pass pm and report
  14. The Following User Says Thank You to sonic 1989 For This Useful Post:
    bodzio012 (25th February, 2018)
