Results 1 to 7 of 7
    Jan 2018
    Default Mercedes Sprinter 315 CDI EGR OFF/DPF OFF/DTC OFF
    Hello Guys,
    Could you please help me to do an EGR OFF, DPF OFF and DTC OFF on a Mercedes Sprinter 315 CDI (2.2 CDI BOSCH EDC16CP31).
    I also have these fault codes.
    P2084, P2078, P1436, P2079, P1437
    I wanna off them too.
    I did the extraction with MPPS and GALLETTO 4 V54.
    I uploaded both maps (with mpps and Galletto).
    Thank's in advance
    Apr 2016
    hi if you still need help send me pm
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    Here it. Not ASC. EGR and DPF off. Disconnect diff sensor.
  4. The Following User Says Thank You to Inquizit0r For This Useful Post:
    SR71 (26th February, 2018)
    Jan 2018
    Are you sure because you didn't even use the original dump.
    Jan 2018
    In any case, thanks !!!
    I'll try and report.
    Inquizit0r's Avatar
    Aug 2013
    Ukraine
    I use your MPPS dump.
    Jan 2018
    Thanks a lot !
    It worked.
    I disconnected the egr valve otherwise the check engine light will stay on (without fault codes).
