Results 1 to 15 of 18
    Feb 2018
    Default EDC17C10 citroen c4 1.6 hdi fail with kess v2
    HW: 9666077280
    SW: 9666729580
    SW upg.: 9679176880
    Hello
    I need ori file...
    I flashed wrong file via obd kess and I do not have ori...
    I flashed the file wcih have same hw and sw numbers, only sw upg was different.
    Thanks, BR
    Myjector's Avatar
    Dec 2017
    Is it original Kess or clone?
    EDC17C10 does only work in Boot with Kess clone (you need to put tricore adapter on it and open ecu)
  3. The Following User Says Thank You to Myjector For This Useful Post:
    jaxone (4th December, 2019)
    Feb 2018
    Default EDC17C10 fail kess
    Quote Originally Posted by Myjector View Post
    It is the kess clone, it allows me to write the file, the fact is that I think the file that I used is not correct, I think I need the same file exactly to restore it from the factory, thanks for answering
    Myjector's Avatar
    Dec 2017
    Did you make no back up or read file?
  6. The Following User Says Thank You to Myjector For This Useful Post:
    Feb 2018
    No, I did not know how to read it, I thought it would work to the same HW and SW, but no, it must also be the same SW upgrade
  8. #6
    Myjector's Avatar
    Dec 2017
    Tomorrow in need to read same ecu, if i have the same number i send you the original file.
  9. The Following 2 Users Say Thank You to Myjector For This Useful Post:
    jaxone (4th December, 2019), jmarininfantes (27th February, 2018)
  10. #7
    Feb 2018
    Ok, thank you very much, really, I need the car to go to work ...
  11. #8
    Dec 2017
    espaņa
    I have a Berlingo file with Ktag reading. I do not think I can serve you.
  12. The Following User Says Thank You to chipcarcordoba2 For This Useful Post:
  13. #9
    sdtsedat's Avatar
    Jan 2015
    Belgium
    You can write with kess clone these ecu's but it is no good idea to do it if you don't have ori file..
    Geniune Kess read this virtual and always have backup file.
    I hope someone have full tricore with same sw and hw
    Sedat Garip
    Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
    Diesel + petrol All cars
    Manual Adblue dpf egr Opf tested working solutions
    Belgium
    With Kind Regards,
    Don't forget hit thank button if i helped.
  14. The Following User Says Thank You to sdtsedat For This Useful Post:
  15. #10
    Jun 2012
    I think you may have a long wait Tho !
  16. #11
    Feb 2018
    Hello, thanks for your answers, I have managed to recover my ecu, with a citroen c4 file from this same forum, thanks for your help and I hope to help you too, a greeting
  17. #12
    Myjector's Avatar
    Dec 2017
    Quote Originally Posted by jmarininfantes View Post
    HW: 9666077280
    SW: 9666729580
    SW upg.: 9679176880
    Hello
    I need ori file...
    Thanks, BR
    Hey your lucky, i have this file from today.
    send my your email pls than i can send it thru mail
  18. #13
    Feb 2018
    Hi, my email is xxxxxxxxxxxxx thanks, do you know someone who has done stage 1 in this file? Thanks
  19. #14
    Northern europe
    Myjector has exceeded their stored private messages quota and cannot accept further messages until they clear some space.....
  20. #15
    Myjector's Avatar
    Dec 2017
    Cleared my inbox
    AUTOTUNER, FLEX ,X17, TRASDATA / NEW GENUIS AND ALIENTECH MASTER OWNER.
    FULL SWIFTEC AND EVC RESELLER
    FILE SERVICE FROM 8AM - 9PM 7/7
    BAPRO 4WD DYNO
  21. The Following User Says Thank You to Myjector For This Useful Post:
