Results 1 to 11 of 11
    Default Problem With ECU MERCEDES ML55 AMG
    Hello!
    I have an ML55 AMG 2001 YM, ECU doesnt send signal to Cylinder 3,4
    Wires are ok, tried to change the ECU from another used car, but car wont start, and couldnt load the code from the old ECU to the other ECU
    I get the message ECU is locked to the car...
    Is it possible to use the Used ECU in the car, or it is just a new one that has to be refitted in the car?
    Thanks for help..
    Default re
    yes sure replace the motorola inside , and if you have tools i can send you virgin file
    Thanks for your reply..
    Can you explain more for me what tools i need
    The Motorola, you mean the inside chip in the box?
    do you have pictures or instructions?
    dimitar's Avatar
    Default hi
    Hi mate can you make this dump virgin.Its from a 220cdi mercedes w211. EDC16C2 95160 eprom
    Quote Originally Posted by dimitar View Post
    Here You go (all the files you need for EZS,ECU & NEC chip inside Key with your Original VIN):
    DK Veteran mariazo84's Avatar
    passs rar please
    Quote Originally Posted by mariazo84 View Post
    passs rar please
    Only dimitar can decide to give or not the password, because these files ment to be only for him..................
    password,?
    Default re ml
    well do you still need support for your ML
    Yes please Help is still needed
    The discussion went on other ways, for other cars than the one i have...
    dimitar's Avatar
    Default hi
    Sorry guys its my fault i should have opened another thread.
