For some reason i am unable to download the file you show.
This whole thing is a right mess with skp
I just downloaded just fine
When I click on the file I am asked to log in.
But I am logged in ?
I try again and log in as if I wasn’t but keeps going to log in screen.
Today the message popped up You can use 9 more times.
I already had V5 installed so I only needed to install what they call the Little V5 file to be token free.
My issue was not being able to update using Pc as it kept telling me communication failed.
To fix this & install the file I had to use the old updated tool V2.4 as V2.5 didn’t work.
Also had to change the Com port.
Once both of the above were done it installed no problem.
Been using it all afternoon as so far no message on the SKP at all.
Litter v5 it token free it right
Yes it’s aupposed to be but there is no confirmation message when you install to advise you of this.
First car I used it on after the message 9 more times didn’t then show it again.
Only time will tell I suppose.
Thanks for all friends i do update today
This is how I updated my SKP900 using the lite file to token free:
I was down to 5 tokens
Down loaded the file on this thread for when you have tokens left
I tried to get comms with my SKP900 but failed using update tool V2.5
So i downloaded the update file V2.4 and used that whilst manually checking which com port to use in Device Manager on XP software. As soon as i did that i got comms with the SKP900 and used the Lite file as an update
Worked straight away took less than a minute to update to token free
Hopefully this will help others who are having comms problems
I did all the upgrade options but the token shows 0
taxo1965 (7th June, 2018)
Hi all.At whom it turned out to update with a token 0? Thanks
Best Regards
taxo1965 (8th June, 2018)
darknezz19 (8th June, 2018), taxo1965 (8th June, 2018)
