After correcting tacho of Master III you have to pull fuse.
WBR, Marek
Hello mates,
customer ask me to do mileage correction on his Opel Movano B 2300cc 120KW year 12/2017.
It's very similar to Renault Master III, it has the same Key, and engine control unit SID310.
Can someone tell me mileage location/s ?
I tried to scan with KTS, AVDI, Wurth and I find mileage only in cluster.
I tried to correct mileage with AVDI and Opel Commander selecting Movano B.
It read mileage correctly but not correct anything.
I tried to correct mileage with ecu and abs disconnected, but the same.
Can someone help me please ?
What I will find in instrument cluster ?
Thank you
Bests
WBR, Marek
After correction I disconnected battery but no way...
Inside cluster I find Fujitsu MB96F6A6 without external eeprom.
I think I corrupt the eeprom content because I tried many times to correct mileage with my AVDI selecting Renault vehicles.
Is any way to read at the bench this mcu ?
Ok I have a problem now.
KM on the screen are different from KM in diagnose.
KM in diagnose: 2031746
KM on the cluster screen: 469xxx.
I read the file of the dash (MCU Fujitsu MB96F6A6 with DP4 via OBD plug.
I tried to correct too with DP4 but no way.
I attach file, can someone give a look and give me a little help, please ?
Thank you
EDIT: Problem solved with AVDI Support.
this should be added to tread avdi fails again when they are saying we never had issue with this dash :!!!!!!!!!!!
Try to read with AVDI like Master III with eeprom (read confdata).
No problem if reading stop at same time.
Then post dump here, I will correct for you and then you can write.
Use Renault old software.
motorsport (5th June, 2018)
Have try but cant read stop afted second i will try read again thanks
It’s not a problem.
Save what it read and post it here.
Your truck has 823 KM ?
Yes it Have
Your file.
Pass PM.
YOUR INBOX IS FULL !
Thanks a lot Worked
