Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
  1. #16
    the car with the original ECU (still can not get another) the car sometimes does not start. when it does not start from error df053. has been changed pump, injectors, sensors. only the ECU is missing. Fan is ok
  2. #17
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Can't help you changing ECUs with different HW and SW, once tested ok but i was sure engines where aproxymatly the same.
    About the problem i have changed ECUs for similar failures but without any DTC ( everything ok for weeks and sudently engine on idle stops with no reason, missing power, etc. But never with DF053.
    Is your DF053 pressure too much low or too much high?
  3. #18
    dijo's Avatar
    Quote Originally Posted by fcarocha View Post
    Hi, forgot ECU!
    Your problem DF053 is Rail pressure related!
    You need to read your fuel Live data to understand what is wrong...
    You need minimum 250bar rail pressure at 250 engine revolution and 1V from Rail pressure sensor...
    If you dont have this, find your leak...
    Good Luck!
  4. #19
    The pressure was tested. it's OK
  5. #20
    Sep 2018
    Argentina, Bahia blanca
    Hello, i have 2 ECUs, the original one is from a kangoo, i cloned the 25080 dump from the original ecu and writted it on the other ecu, the car start with both, but with the cloned one does not accelerates... i need the password of the virginfile to virginice the second one and try to make it work
  6. #21
    rafal's Avatar
    UK - PL
    Quote Originally Posted by psabad View Post
    read #17......................
    need help
    now my goal is to buy xp-005
    who will help?
  7. The Following User Says Thank You to rafal For This Useful Post:
    Louislesinge (28th September, 2020)
  8. #22
    Jun 2017
    French Jungle
    If you have Clip, connect original ECU and send command "save data" then connect new ECU and send command "write saved data" (from original to spare).
    Many times if you mix Eeprom and flash data ECU loses injectors codes.
    Greetings,
  9. The Following User Says Thank You to Louislesinge For This Useful Post:
    rafal (28th September, 2020)
  10. #23
    Nov 2017
    Dobruja
    some help...
    Delphi trw have often some dry contacts on the board. Resolder all that ecu pins and with the original dumps it will work. Good luck
