Results 1 to 15 of 23
    Default clone or virgin ecu delphi megane 2 1.5 dci
    I have problem with
    DDCR 80967B
    R0410B015B
    8200259832
    HOM8200264689
    I'm trying to clone (or per vigem) and ecu
    DDCR 80944H
    R0410C066A
    8200303619
    HOM8200129063
    if put vigem, when put in the car is programmed?
    To read the memory, do I have to leave the ECU? or is there another way?
    DK Veteran mariazo84's Avatar
    you need virgin and good
    I put the first line to ffff but it gave an error, the car does not start.
    I put the first line to fff (should be programmed automatically). car does not start, fan works. I copied eprom 25080 from one to the other it happens the same.
    I attach the original file of the car and the 2 ecu file I have used (one 95080 and another 25080). in the car is 25080
    rafal's Avatar
    UK - PL
    virgin 25080..................
    need help
    now my goal is to buy xp-005
    who will help?
  7. The Following 3 Users Say Thank You to rafal For This Useful Post:
    artini (16th March, 2023), fcarocha (3rd March, 2018), psabad (28th September, 2020)
    I'll test and give you feedback
    the car does not start. the fan works. ecu is not detected by the diagnosis
  10. #9
    rafal's Avatar
    UK - PL
    have you coded ecu?
    need help
    who will help?
  11. #10
    I do not have access to the diagnostic machine
  12. #11
    The ecu used was a clio. and the car is a magane. Is the virgin file the same?
  13. #12
    some help...
  14. #13
    Louislesinge's Avatar
    Jun 2017
    French Jungle
    Hi all,
    fcarocha
    Tell us what was the problem before you tryed another ECU?
    Maybe it was the same problem with the original ECU. This kind of ECUs are easy to make start by Eeprom
    swap , but on Mégane 2 there are many problems with the injection relay and they show the same symptom you'are talking about.
    Greetings,
  15. #14
    the car crashes randomly. Sometimes the car does not start. other times it starts, after some time goes down. was switched pressure pump, injectors. I think it's ecu. I've already got 2 used ones that can not be used in the car by changing the eprom 25080. Now I'm trying to copy everything and flash, but I'm not able to boot.
  16. #15
    Jun 2017
    French Jungle
    Ok, but with original ECU are there different symptoms, fan doesn't run, ready to start?
