Results 1 to 15 of 25
    aftermath's Avatar
    Mar 2008
    Default Getting Cross EPG to work in E2 images
    now we can have an 8 day EPG in E2 images, also in DGS based images using CrossEPG.
    download this file and FTP it to tmp folder .... http://www.crossepg.com/downloads/cr.../download.html
    open putty or other telnet programme
    login and at the curser put
    cd /tmp
    next line put
    ipkg install crossepg-enigma2_0.3.2-svn-33_sh4.ipk
    i had to do that twice for some reason for it to install
    reboot GUI
    then FTP to the file /etc/init.d/rcS ...right click and choose edit
    and before the line
    /usr/local/bin/enigma2
    add this line
    /var/crossepg/crossepg_epgmove.sh
    Example:
    echo "starting e2->"
    reboot gui again
    now on menu button on remote go to setup, you will see new option " crossepg"
    set up which sats you want in your EPG and other settings
    now run crossepg programme in plugins
    I have updated my image to AAF summerdream 2.0 based on Tideglo 0.5.5.
    The image is pretty good, better than the previous version I think. On that version 0.5.0, CrossEPG was working good providing you were sticking to the default skin.
    On the one, 0.5.5, the pluggin installs OK and you can configure the settings etc fine. But the GUI crashes when you run it, every time for me even with the default skin ON. It goes through dowloading the titles and summaries, parses the titles OK but crashes at different stages when parsing the summaries. GUI just reboots.
    Note that with the new tideglo version, you do not need the fix for crossepg to sync correctly:
    Enigma2 installation (ipbox cuberevo)
    with a unix compatible editor edit the file /etc/init.d/rcS and before the line
    add this line
    Example:
    Has anybody got this going with the newer image?
    Cheers
    PT
    aftermath's Avatar
    Mar 2008
    If you hang about for a few more days , the new PKT image will be out and this will already have Crossepg in it.
    Cheers,
    Was hoping to keep that image for another while and try to fix the issue.
    Pt
    I figured out what to do with the crash.
    When you run crossepg for the first time, do not select any satellite from the crossepg setup menu and run it once. I am assuming it creates empty dbs.
    Then select the sat you need and run it again. It runs perfectly through, restart the GUI and the EPG is synched!
    aftermath's Avatar
    Mar 2008
    Default E2 0.7.5 ipkg & CrossEPG
    this is a patch for latest E2 images to get crossepg to work on Python 2.6
    ipkg:
    FTP the ipkg file to temp
    then in Telnet run following commands
    * cd /tmp
    * tar -xvzf ipkg_var.tgz -C/
    CrossEPG
    do same with crossepg file as ipkg file
    * cd /tmp
    * ipkg install crossepg-enigma2_0.3.3-svn-33_sh4.ipk
    V.I.P. Member despdan's Avatar
    Midlands Ireland
    Have crossepg installed & now getting the following error any ideas what i can do ( sifteam-e2-ee-beta5b-cuberevo-usb.tar image installed ) :
    Some scripts not available, system plugins/crossepg/bad magic number in :
    usr/lib/enigma2/python/plugins/system plugings/crossepg/-init-.pyc
    Also looked for below but nothing in that file matches:
    add this line
    Member grizzlyt's Avatar
    Oct 2008
    Quote Originally Posted by despdan View Post
    Bad magic number means that the Plug-in you installed isn't compatble with th Python version.
    They have changed to Python 2.6 since 0.7.5, all versions before are in 2.5.
    IP Box HD 9000 2xS2 tuner
    Dreambox 7025-SS
    Smart MX 28-IDTE IQ 2040
    Sammy 9500-Sammy 9400-Sammy 9000
    Triax 120 cm-Titanium 2 LNB's
    Default PKT 7.5.1
    Hi, I have the same problem with e2 PKT 7.5.1. : system plugins/crossepg/bad magic number in :usr/lib/enigma2/python/plugins/system plugings/crossepg/-init-.pyc , any idea?
    DK Veteran freck's Avatar
    Jul 2008
    Dark side of the Moon
    Are PKT images the only images with the cross epg plugin pre installed.
    Finally getting my ip9000hd tomorrow so I'll be on for some fun and games.If I can get cross epg up an running ok I'll be one happy camper.The epg is the only thing that pisses me off with my current setup.....barely now and next.
    Freck
    doh...question answered in aftermaths first post...sorry.
    aftermath's Avatar
    Mar 2008
    any image can have Crossepg, if you go on CrossEPG web site , they give explanations on how to install either to DGS based image or E2 image.
    Personnaly i think it looks better on E2 images, it looks a bit basic on DGS based images..
    1 word of warning though , some DGS based images dont leave much memory space after the image, and if you install cross epg and fill it up your box will go into panic,,.. NLB 11102 should be fine , ive had it running on that..
    Jul 2008
    i'll probably be on here tommorrow with lots of questions re ipbox 9000 so i'll keep quiet till then.
    Need some info on incubus aswell so hopefully ill have the box tomorrow for a little play around.
    Freck
  13. #13
    aftermath's Avatar
    Mar 2008
    i must add this, the latest version of PKT E2 ( 8.9.1 ) seems to crash during the EPG scan, Just wait a long time as it is still working, ( maybe 30 mins ).
    another way to do it is :-
    and a big thanks to Jahu from SU
    just download the sky.epg file from http://hqsatellite.com/satmate/skyuk_epg.dat.gz, unzip it, rename it to ext.epg.dat and copy to crossepg folder. Then i go to the Crossepg menu, extra, then just select "Load Data".
    My crossepg.conf looks like this:
    db_root=hdd/crossepg/ or could be media/usb/crossepg ( for usb stick users )
    lamedb=lamedb
    otv_provider=skyuk_astra2_28.2|skyuk_astra2_28.4
    auto_boot=0
    auto_daily=0
    auto_daily_hours=4
    auto_daily_minutes=0
    auto_tune=0
    auto_tune_osd=0
    auto_daily_reboot=0
    manual_reboot=1
    enable_importer=0
    show_plugin=1
    show_extension=1
  14. #14
    Great Post Guys - Thanks for the Info
  15. #15
    Member Oadbylad's Avatar
    Default Crossepg
    Well i cant get it to work on Gemini 5 when ive entered the
    final command in telnet i get this error
    collected errors
    Package for crossepg-enigma2 found, but incompatible with the architecture configured
    cannot find package crossepg-enigma2.
    root@dm800:/tmp#
    any help i would be greatful
