here your file immo off
Hi everyone i have a 1000% good solution and correct for all edc17 mev17, med17 ecu immo off.post me private tothzsolt1982@gmail.com
hi please annyone can remove immo from that ecu
Hi all,
Immo off with RocketDump works 100% on this ecu EDC17C60, C10, Med17, mev17, mevd17
esse (10th December, 2019)
Hi all,
I search immo off file for Berlingo 1.6 HDI 98hp edc17C60.
Thank you very much in advance!!
here your file off
Theoros (21st December, 2019)
Hello friend ESSE, please I tried to do FAP off this ECU 0281032456 EDC17C60 9814182680 from Peugeot 5008 1600 hdi , so now car starts some seconds after that engine cut down , diagnosis machine shows P1631 and P1621, I was reading that fault may be is Immo not syncro, could you please make immo off to try again with Ori ECU??
regards and thanks in advance
Here both file,
virgin and off
OK friend, thanks a lot, I gonna try with Ori ECU, regards
Hi ESSE, your file works, car stars , but I thing there is something bad in my ECU because cars stars just 5 seconds after that engine cut down, maybe ECU damage, I will find second hand to try ,,
regards and thanks a lot again,,
Hello friend, and Happy new year, I finally found other ECU same reference, I gonna try with this, please could you make immo off??
regards
Thanks a lot friend, Car starts very well, you are the best
regards
esse (8th January, 2020)
Hi all,
I search immo off file for 208 0281032456 9806460480 edc17C60.
Ask Esse , he can do it perfect...
