Results 1 to 15 of 24
    Sep 2016
    south africa
    Default Tl866cs programmer
    I have tl866cs programmer bought for me. I am struggling to write a am29f010 and am29f010b flash chip from a dupec ecu. I can't erase the chip. I tried many chips but same problem. I unprotect but its not working. If someone can tell me where I'm going wrong please help. I must erase before I can write. Thanx.
    I can read it only but not erase
    Sent from my WAS-LX1 using Tapatalk
    Feb 2013
    UK Bristol
    If you desolder this memorys from ECU, you can just READ tehn,,
    For Programming you should buy new Memory and then flash it.
    DR Race's Avatar
    Dec 2017
    Dracula's country
    Sorry my bad , this chip can be erased and new programmed, no need for new one !
    Trimis de pe al meu SM-G930F folosind Tapatalk
    29f010 is flash based and not OTP. Try a different programmer.
    heteromies
    Guest
    Quote Originally Posted by mister opel View Post
    NO DEVICE found? So is your programmer setup ok or is it clone...?
    Sep 2016
    south africa
    Quote Originally Posted by heteromies View Post
    I suppose it is a clone as it's bought on wish for relatively cheap. But it works nice on all other chips. All drivers installed and software working with hardware nice. Only can't erase chip above
    Nov 2016
    Im write like this.
    Sep 2016
    south africa
    Quote Originally Posted by gumacz100 View Post
    Im write like this.
    And how do u erase? I can't erase. That's my problem
    raceshadow's Avatar
    Mar 2016
    Czech Republic
    I can see 29C010B on the photo.
    Sep 2016
    south africa
    Quote Originally Posted by raceshadow View Post
    It is a AM29F010B
    Sep 2016
    south africa
    Still nothing guys?
    Nov 2015
    Did you try to resolder the adapter?
  13. #13
    Jun 2017
    Ukraine
    Fill the "FF" block and press the programming chip.
    The Erase function may not be supported.
  14. #14
    Sep 2016
    south africa
    Quote Originally Posted by ussr100 View Post
    Adapter seems fine. I suppose the erase function is not supported. However the reviews on this programmer was real good. It's a real pity.
    I'll try to get hold of the manufacturer for their info.
    If anyone maybe knows how to erase this chip with minipro pls do let me know at some point.
    Tnx forum
  15. #15
    Sep 2016
    south africa
    Tnx forum
    What do you mean with fill the FF block? You want me to try and program the chip with FF data all the way?
