sdtsedat (4th March, 2018)
Does anyone know how worked this chip?
I dont know what is conected on connector(on picture named like unknown)...LED,switch...?
I want install this chip into Lancia Lybra 1.9 jtd 2002y
Markings on the chip( right side below barcode) is F08RAPID-LPI
Thanks in advance for any help!
Sedat Garip
Chiptuning Remapping, file service, stage 1 & 2 dyno tested.
Diesel + petrol All cars
Manual Adblue dpf egr Opf tested working solutions
Belgium
With Kind Regards,
Don't forget hit thank button if i helped.
I got this chip and need to connect to the Lancia car.If a possibile?Told me to work onto Lancia 1.9 JTD engine.
I'm afraid to try it because I do not know what be connected on the connector named "unknow".Just this.
goes to common rail sensor , fuel pump or MAF
can you be more specific?specifically where? tnx
put better photos of main connector!
But i have on my chip more two separate wires for voltage and for "unknow" connector.Chip on video is higher
read ecu by obd and we do good tune for you
FILE SERVICE
I dont have tool for reading ecu.I just try istall this.
ovaj powerbox nije ti nista,instalira se na map sensor mislim i senzor rail pritiska ne valja te nista
bolje remap i nemas krize pozdrav best regards!
Proffesional ECU & TCU Tuning
Petrol and Diesel Engines
File Service
